neo Posted May 11, 2002 Share Posted May 11, 2002 is the chassis number stamped on a westy chassis if so where will i find it Quote Link to comment Share on other sites More sharing options...
Westfieldman Posted May 11, 2002 Share Posted May 11, 2002 Mine is stamped on the brace bit under the carbs[drivers side] at the gearbox end. Paul. Quote Link to comment Share on other sites More sharing options...
Mark Stanton Posted May 11, 2002 Share Posted May 11, 2002 And often on the front bottom cross member behind the radiator . If no chassis number is located then walk away from it as you would any car Quote Link to comment Share on other sites More sharing options...
