spyderman Posted May 9, 2002 Share Posted May 9, 2002 Hi Ive just collected a 2L Zetec and am having some work done on it and am thinking of having a quick shift fitted. I will be using the car for road use with some track days, sprints and hillclimbs thrown in. On driving the car home i found the gear shift a little sloppy (The gear knob seamed to twist from side to side) which made things feel a bit odd. While i suppose i could fit another knob i was woundering if anybody has experienced both shifters? Quote Link to comment Share on other sites More sharing options...
Nick M Posted May 9, 2002 Share Posted May 9, 2002 I have a quick shift on my type 9 box, and it does make a noticable difference. It's the icing on the cake when you use a straight cut, close ratio box. Quote Link to comment Share on other sites More sharing options...
Mike H Posted May 9, 2002 Share Posted May 9, 2002 Got a Westfield quickshift on my MT75 - definitely recommended. Mike Quote Link to comment Share on other sites More sharing options...
Richard Salisbury Posted May 9, 2002 Share Posted May 9, 2002 Ditto all that! Got an MT75 with Westfield quickshift - much better than standard. Go for it. RS Quote Link to comment Share on other sites More sharing options...
bannaman Posted May 9, 2002 Share Posted May 9, 2002 Thanks I recon I'll go for it, in penny in for three hundred quid??? Quote Link to comment Share on other sites More sharing options...
JohnCh Posted May 9, 2002 Share Posted May 9, 2002 I added the Quaife quickshift to my Type 9 gear box and it made a huge difference to the shift quality. I bought the model designed for the c******m (it's angled back a bit to give added knuckle clearance between the shifter and dashboard) assuming it would be a direct bolt-in, but it did require some machining around the collar to fit Westfield's mounting bracket. -John Quote Link to comment Share on other sites More sharing options...
