Crash test dummy Posted September 23, 2009 Share Posted September 23, 2009 Custom made swirl Injection swirl pot that fits to the rear bulkhead. Standard bootbox fits perfectly. -6 feed, return and bleed, -8 outlet to high pressure pump. £35 plus the postage. Link to comment Share on other sites More sharing options...
Tigger Posted September 23, 2009 Share Posted September 23, 2009 Hey Crash, you got any paddle clutches you wanna sell? I'll give you a free bump Tiggs Link to comment Share on other sites More sharing options...
Crash test dummy Posted September 23, 2009 Author Share Posted September 23, 2009 You don't give up easy do you! Link to comment Share on other sites More sharing options...
Tigger Posted September 23, 2009 Share Posted September 23, 2009 You don't give up easy do you! Neither do you Link to comment Share on other sites More sharing options...
shakey Posted September 24, 2009 Share Posted September 24, 2009 you have pm , fine sir. Link to comment Share on other sites More sharing options...
Crash test dummy Posted September 24, 2009 Author Share Posted September 24, 2009 Replied to Paul. Link to comment Share on other sites More sharing options...
Ninja Posted September 24, 2009 Share Posted September 24, 2009 I don't need one, but that's a mighty fine looking swirl pot... (free bump) Link to comment Share on other sites More sharing options...
XTR2Turbo Posted September 24, 2009 Share Posted September 24, 2009 It looks pretty and nicely shaped for the space etc and well done for making and offering but is the 'Swirl' in the name because you also need the fuel / water or whatever it could be used for to enter and rotate to remove the risk of air bubbles etc. That's why they are normally round and the inlets point to one side of the circular face. Not much of a problem if full but could be if you get surge in the main tank and the level drops. Might be an optical illusion but is the outlet at the lowest point of the tank? Looks about 15 mm up. Why not on the bottom? I could be talking rubbish of course. David Link to comment Share on other sites More sharing options...
Crash test dummy Posted September 25, 2009 Author Share Posted September 25, 2009 Perhaps best discussed in Techie Talk not in the For Sale section??? Link to comment Share on other sites More sharing options...
Jock Posted September 25, 2009 Share Posted September 25, 2009 PM sent Link to comment Share on other sites More sharing options...
pete g Posted September 25, 2009 Share Posted September 25, 2009 steve if its not gone i may have it for when i convert to injection on the v8 Link to comment Share on other sites More sharing options...
Crash test dummy Posted September 25, 2009 Author Share Posted September 25, 2009 Jock and Pete you both have mail. Link to comment Share on other sites More sharing options...
Jock Posted September 25, 2009 Share Posted September 25, 2009 I'll pass thanks, good luck with the sale. Link to comment Share on other sites More sharing options...
Crash test dummy Posted September 25, 2009 Author Share Posted September 25, 2009 Still available. Pete g said he'll reluctantly have it if it doesn't go Link to comment Share on other sites More sharing options...
