Cleggy's Spyder Rebuild 17 07 09
Thanks Dave - what I have not let on yet is that I am doing every little job except the main thing that needs doing - getting the body to sit on straight
mental note - must stop avoiding this
tonight sees the speedo cable routed with a hole drilled in bulkhead and three small brackets made up and welded to the chassis - tested lock to lock and all appears good
I also altered the bracket that holds the brake fluid resevoir and lifted it up a bit so there is more drop on the pipes
hopefully fuel sender will arrive tomorrow
  • 2 weeks later...
Bit more done tonight - revised the spec for the fuel tank and decided on 8mm ID fittings which should be more suitable for the twin carbs conversion - also ordered a breather valve for the tank which will sit next to the recess where the fuel dip tube will be located
oh and taxed the westy today - ride out tomorrow me thinks  :t-up:
just me and you mate for the ride, bryans booked.  cu at 2
and Dave too  :cool:
:t-up: don't forget your sun glasses, ive got some new shiny bits  :cool:  :cool:
yup - looking forwards to seeing the mean machine
got my finger out tonight and started on the seat mounts
pulled the old seat covering to reveal the seat shells - might have guessed they might be in a bit of a poor state and would need some repair work - just as well my fibreglass repair kit arrived a few days ago that I purchased off ebay
made up 8 identical plates and drilled - chopped up some bolts and welded in place flush
spyder has had a bit of a back seat over the last few weeks since the weather changed and have quite a few blats out plus a week in Disney with the kids which was a much needed break
thanks to a very kind WSSC member who sent me a book on how to make a beetle handle I have (in my mind) spent a fair amount of dosh
well what do you need to make a swing axle beetle handle? assuming you dont want to do a later type IRS conversion)
1. rear camber compensator (stops the A*** end lift up under hard cornering) - basically a leaf type spring that mounts under the gearbox - the spring rests on the drive shaft tubes and helps to prevent downwards movement
2. lower rear to alter camber to help prevent again the rear outer wheel tucking under
3. fit a front anti roll bar
4. fit front beam support
5. maybe get a slightly wider tyre on the rear
6. fit some castor shims - sits between the front axle beem and chassis - required because the front end has been lowered with the axle adjusters altering castor causing problems with self centering and high speed stability
7. maybe invest in some spaz adjustable shocks
gonna cost 500-600 quid but will be worth it I think
after that much tinkering with suspension geometry - didnt realise the amount of adjustment that was available on such an old design - although I shall not be attemting to mess around with this myself
Oh and also got some secondhand twin carb dellorto's 34's lined up too (called baby dells) - these will sort the hood clearence issue with the single centrally mounted carb
Hope to pick them up at the weekend and also to get over to the guy who is going to make up the tank for me with the mounting bracket and dip tube
progress being made - just about  :suspect:
is "HDC" on the bins ..  House de Cleggy?
silly b****r :laugh:
:laugh:  maybe I should get an HDC sticker for the westy and the spyder - maybe they might try to wheel them up the yard to the dustcart
Looks great alongside the wessy in the photo Cleggy :t-up:
But who's nicked the engine  :p  :p  :p
Nah, its "Home of Dem Cars" of course, stupid! :D  :D  :D
or 'higher disposal charge' to cover for all the post build debris going in those bins   ;)
surely 'deux' cars  :)
