FW500 Posted July 16, 2009 Share Posted July 16, 2009 I have decided to sell my Westfield to help finance a property abroad. I really don't want to see it go but finding 100% mortgages at the moment is a little difficult. Overview Westfield SEiW built in 2008 from a factory supplied rolling chasis. Registered in July 2008 on an '08 plate. The car was built to house an engine that I had invested many many thousands of pounds and 10 years of development into. Since it's SVA last year the car has completed 3,000 miles. I run the car at around 1Bar of Boost - which is somewhere around the 300Bhp mark. 2 Bar would give you around 450Bhp. I have run this engine at over 450Bhp in the car it was in before I dropped it into the Westfield but I don't have the balls to go that far with it in this thing. Engine Vauxhall 2Ltr 16v Turbo (C20 LET) Overbored by 0.5mm V-Tuning Ported and Polished Coscast Head T38 Turbo ARP Rod Bolts Arrow Rods Oil Spray Bars for under piston cooling Z20 LET head gasket SBD Steel Valves with wasted stem on the inlet Titanium Valve Caps Double Valve Springs C20 XE Inlet Cam SBD/Kent Vernier pulley SBD Shallow Sump 6 Pint Electronic Accusump System Mocal Oil Cooler Mocal Oil Catch Tank Jenvey Tapered Throttle Bodies Jenvey Throttle linkage SBD Inlet Manifold SBD Ultra small 55amp 3.2kg Alternator & Mount kit Nissan Pulsar GTI-R Plenum PWR Charge Cooling system Aquamist Water Injection Magnecor Ignition Leads SBD Carbon Spark Plug Cover Viper Induction system MSD Ignition control MSD Blaster 2 Ignition coil SBD 70deg thermostat Fuel Lab Adjustable Fuel Pressure Regulator Bosch 600cc Injectors Apexi AVC-R Boost Control Bosch 044 Fuel Pump Bullet Fuel Filter Autronic SMC Fully Programmable Management Billet Lightened Flywheel Helix Paddle Clutch Tilton Hydraulic Clutch Assembly Westfield V8 Radiator Peter G Stainless exhaust manifold Full Stainless Steel exhaust (96dB) RedTop Gel Battery Varley Battery cover Borg Warner T5 Gearbox 3.92 LSD 2 x Husky Radiators Yellow Silicone Hoses AH Fabrication Foam Filled Fuel Tank Brakes/Suspension AP Racing 4 Pot Brakes on the front Golf brake setup at the rear Standard Westfield adjustable coilovers Exterior Westfield FW Bodywork in Yellow Carbon Mods Aeroscreen Carbon Mods CSR Front Arches (with mudflaps) Carbon Mods Rear Arch protectors Carbon Mods 75mm NACA duct Clear Front Indicator lenses M&P Front Headlamps Hinged, lockable boot RAC Roll bar with Petty Strut LED Rear Lamps 15in Team Dynamics Pro Race 1.2 Toyo PXR888 Tyres SPA Carbon mirrors BMW E36 side repeaters Brushed Alluminium raised fuel rig Interior Flocked Dash Stack ST700-SR Dash Display Renault Clio Indicator Stalk (Controls lights, horn, indicators) Motosign warning light display Toggle switches for Accusump and Charge Cooling pump Apexi AVC-R Boost Control display Aquamist flow-meter display 2 x flame beater fire extinguishers JK Composite part carbon seats with yellow/black pads Factory lowered floor Momo Gear knob and handbrake handle Sony 580 Bullet Cam kit Luke 3in 4 point harnesses Sparco motorsport horn I'm not going to take any offers on the car - if it sells it sells if not - I just don't buy the property abroad. I'm also not going to break any of the above spec to be sold separately. The price is £19,950 and I'm based in Plymouth. Call: 07021 556 961 Link to comment Share on other sites More sharing options...
Matt Seabrook Posted July 16, 2009 Share Posted July 16, 2009 Link to comment Share on other sites More sharing options...
Cleggy the Spyder Man Posted July 16, 2009 Share Posted July 16, 2009 very desirable ... good luck chap Link to comment Share on other sites More sharing options...
David H Posted July 16, 2009 Share Posted July 16, 2009 very nice Link to comment Share on other sites More sharing options...
h4muf Posted July 16, 2009 Share Posted July 16, 2009 Quick,pass me some tissues! Link to comment Share on other sites More sharing options...
PeP Posted July 16, 2009 Share Posted July 16, 2009 Quick,pass me some tissues! Quick pass me £19,950 Link to comment Share on other sites More sharing options...
FW500 Posted July 17, 2009 Author Share Posted July 17, 2009 Thanks chaps. It's going to be a difficult car to sell I'd have thought but I'm not in any rush. Link to comment Share on other sites More sharing options...
karlos Posted July 17, 2009 Share Posted July 17, 2009 b****y hell mate, this is out of the blue!! Link to comment Share on other sites More sharing options...
perksy Posted July 17, 2009 Share Posted July 17, 2009 Top Spec' VX Good Luck with the sale Link to comment Share on other sites More sharing options...
Jackv4 Posted July 17, 2009 Share Posted July 17, 2009 this cant of been a easy decision thats one h*ll of a car,totally it best of luck with the sale johny Link to comment Share on other sites More sharing options...
STROMA Posted July 18, 2009 Share Posted July 18, 2009 i see you still keep a keen interest in Westfields since you sold the car Johny.....i can eventually see you having another one.....hope the bike is what you hoped for......one of the best things my missus and i ever did...buying the car from you cheers Stroma Link to comment Share on other sites More sharing options...
Jackv4 Posted July 18, 2009 Share Posted July 18, 2009 i see you still keep a keen interest in Westfields since you sold the car Johny.....i can eventually see you having another one.....hope the bike is what you hoped for......one of the best things my missus and i ever did...buying the car from you cheers Stroma yep,must say i do miss her(a lot) but cant look back now, unfortunataly im back down to aberdeen tomorrow(sunday) for surgery(monday morning) on my back again,things not been going to well here, hope everythings turned out fine at your end and keep having loads of fun in eh car must say i do still these motors johny Link to comment Share on other sites More sharing options...
FW500 Posted July 22, 2009 Author Share Posted July 22, 2009 No longer for sale. Link to comment Share on other sites More sharing options...
