20XE
chippy
Hi all
After a little bit of research on the net and a closer inpsection to my engine i have found out i have a KS head not a coscast as i have a oil gallary core plug. Which was abit of a disapointment i have to say :(
Should i get rid and find a coscast head or is it worth the risk? Is it a very common problem or is it just something that mite happen depending on how lucky you are?
Cheers :)
Link to comment
Don't worry about it. Chances are that it has already gone porus and repaired long ago...! For the money a Coscast head fetches (for some reason), you could get a KS repaired anyway ;)
Link to comment
As Stu says dont worry.
Only a few go and if it does its an easy fix.
Besides the ports on the Cosworth head were no better than the GM/KS.
Link to comment
