Trems Posted October 1, 2008 Share Posted October 1, 2008 Hi guys, i'm looking to take a week off in November to get a load done on the BEC, project in particular i'd like to get hold of the following by then: - Sierra column (and steering wheel if poss) - Sierra handbrake assy - Sierra diff + shafts (LSD if poss but anything considered) I'm also open to any other bits you think might help with the project! Link to comment Share on other sites More sharing options...
MCB Posted October 1, 2008 Share Posted October 1, 2008 Hi, I have a upper steering column, modified by westfield and a lower steering colum also modified by westfield Would these be any good? Mark Link to comment Share on other sites More sharing options...
smegablade Posted October 1, 2008 Share Posted October 1, 2008 PM sent ref handbrake Link to comment Share on other sites More sharing options...
Tim Reid Posted October 1, 2008 Share Posted October 1, 2008 I have a spare 3.9 diff but you will need to find an input flange. Link to comment Share on other sites More sharing options...
1993sei Posted October 1, 2008 Share Posted October 1, 2008 Which engine are you using?? BEC's need at least 3.6:1 for a 918/893 blade others can be worse for example a zx10 will do about 100mph flat out with a 3.6:1! Also Steve at speed shack has a steering column £20 01895 - 449066 I know this because I had the other one he had! (the early aluminium mounting bracket version) He has probably got all the bits you would need to get it done. Talk to Andy at AB performance about bike engines before you buy to many expensive but wrong parts like I did. Regards Dave Link to comment Share on other sites More sharing options...
Trems Posted October 6, 2008 Author Share Posted October 6, 2008 Using a 893 blade engine mate, thanks for the number. I've got most of the engine bits i need, my kit is all from a megablade so has all the westfield-fitted stuff, clutch, baffled sump, exhaust etc. Thanks Link to comment Share on other sites More sharing options...
