Funbob reckoned you looked like David Essex last night :laugh:
who  ???
must be before my time  ;)
  • Replies 3.4k
  • JeffC
    979
  • Pilot Pete
    686
  • slippy
    319
  • boblog
    241
David Essex's dad, maybe.. :laugh:
cheeky t**t  :laugh:
yes noticed we had a special guest appearence from the britas empire  mush  :p  :p
if you cross
with
you would get a good likeness  :p  :p
when I came back from the toilet I would been forgiven If I thought I had walked into an audition for snow white with Log Slipp funbob and Mark stood together  :p  :p
This thread should be turned into a comedy show :D  :D  :laugh:  :laugh:
Roll on Sunday ;)
would come back with a witty comment but I have spent this afternoon turning my pedals back to front to give me about another 4"
still can't get the b****y  travel out of the brake pedal tho  :bangshead:
new throttle cable is a mile short so I have straightened up the old one as best I can, hope it does the job because with my new comfy seating position I will be on a mission this weekend  ;)  :t-up:
Pete pick up your chain just the one tho as you may not like the price  :suspect:
Probably pop round after tea. :t-up:
-Pilot Pete :bangshead:  :bangshead:  :bangshead:
did you look at removing the spacers and  cutting that rod down  to take up the travel :suspect:  ???  ???
did both mate ,rod doesn't make any difference but needed doing as I have move the pedal back 4"
if I take 1 of the 6 shims out between the caliper the brakes lock up when I tighten the bolts back up
adding a drop of brake fluid when the pistons were closed has helped a wee bit but still nowt like yours
wounder if a new set of pads may make a difference  ???
QUOTE
looks like its slicks for Sunday
........then wets, then slicks, then wets, slicks, wets, slicks.........  :bangshead:  :D
