HULLB Posted August 27, 2008 Share Posted August 27, 2008 Just picked up my SDV starter kit (Mazda based) and given the quite high cost of completion kits thought it never to early to start looking for genuine used westy parts. Would be very interested in buying a crashed wide bodied westy to use as a donor, or interested to hear from anyone with major parts such as shocks, fuel tank, windscreens, seats, steering rack, exhausts etc. (I realise the used parts for sale section is very good - before some helpful person points that out to this rooky!). Thanks, Brian. Link to comment Share on other sites More sharing options...
RobC Posted August 27, 2008 Share Posted August 27, 2008 Shouldn't this be in the wanted section` Link to comment Share on other sites More sharing options...
Tim Reid Posted August 27, 2008 Share Posted August 27, 2008 I could have a set of Westfield supplied Spax shocks for sale if you are interested. They have done 12,000 miles and working fine (no bounce on rebound). Due to age they are not the best looking but if you are looking to save money let me know. From a factory built Zetec engined Westy. Steering wheel might also help you... My Ebay Listings Link to comment Share on other sites More sharing options...
Mark (smokey mow) Posted August 27, 2008 Share Posted August 27, 2008 You might have some problems if you try to fit a standard Westfield (Mountney) steering wheel to a Mazda kit. The Westfield wheel has it's fixings on a 101mm PCD and is designed for a mountney classic boss kit. Whist these are available for the standard Allegro steering column I couldn't source one myself for an MX5 upper column. In the end I had to by a Momo MX5 boss kit and then get an adaptor ring made up to allow me to mount the wheel on the adaptor. See pic If you don't mind a bit of work then this isn't too bad to do, otherwise I'd reccomend either sticking with a standard MX5 steering wheel or alternatively buying a Momo wheel and hub. If you're also planning on using the Mazda clockset you might also find you wont be able to read them through the wheel if you change to a smaller aftermarket wheel. Link to comment Share on other sites More sharing options...
mark.anson Posted August 27, 2008 Share Posted August 27, 2008 Ive got lights etc for sale. look down the page a bit Mark Link to comment Share on other sites More sharing options...
stu999 Posted August 27, 2008 Share Posted August 27, 2008 You might have some problems if you try to fit a standard Westfield (Mountney) steering wheel to a Mazda kit. You might find this issue with many other parts for the Mazda SDV too - e.g. shock absorber lengths might be different, spring rates different, etc, etc... Link to comment Share on other sites More sharing options...
Mark (smokey mow) Posted August 27, 2008 Share Posted August 27, 2008 Shocks and springs etc are all identical to the other car engined SEIW variants, part number 3740056 for the set of 4. Physically the chassis body/tub's don't vary significantly, only having some minor tweeks/ additional brackets etc to take the donor MX5 parts and different wishbones to accept the mazda's hubs and uprights. If you're not sure on anything send me a PM. I also didn't buy the completion pack for my kit, both due to price and the fact that I'm chaning so much on my build most of it would've be used, so I had to source alot of my parts separately from Westfield. The other advantage to this is that it spreads the cost of the parts over the duration of the build rather than paying for everything up front and then trying to find somewhere to store it. Mark Link to comment Share on other sites More sharing options...
cashy Posted August 27, 2008 Share Posted August 27, 2008 i may have a rAC ROLL BAR NEXT MONTH Link to comment Share on other sites More sharing options...
dombanks Posted August 28, 2008 Share Posted August 28, 2008 smokey, i didnt buy the completion kit for my sierra sdv, totally agree with you in not doing so. it meant a much more involved build and possibly more hassle but ultimatly more rewarding. ebay is your friend here, just keep an eagle eye out. Link to comment Share on other sites More sharing options...
HULLB Posted August 28, 2008 Author Share Posted August 28, 2008 Thanks to all the above for advice, I'm sure it will benefit one or two other people also, seems this is a really useful site. Cheers, Brian. Link to comment Share on other sites More sharing options...
Tom Frankland (T3OMF) Posted August 28, 2008 Share Posted August 28, 2008 i may have a rAC ROLL BAR NEXT MONTH Will this be new? May be intrested Link to comment Share on other sites More sharing options...
Mark Stanton Posted August 28, 2008 Share Posted August 28, 2008 QUOTE May be interested wise If your avatar photo is anything to go by - check your helmet clearance to top of bar you want at least 50mm Link to comment Share on other sites More sharing options...
Tom Frankland (T3OMF) Posted August 28, 2008 Share Posted August 28, 2008 May be interested wise If your avatar photo is anything to go by - check your helmet clearance to top of bar you want at least 50mm Thanks Mark Ill bear that in mind Link to comment Share on other sites More sharing options...
wipper Posted September 1, 2008 Share Posted September 1, 2008 I may have a pair of windscreen pillars with mirrors. Link to comment Share on other sites More sharing options...
