chazpowerslide Posted July 25, 2008 Share Posted July 25, 2008 Aluminium Dry sump tank. 120mm Diameter, tank 480mm plus 70mm to the top of the filler. Unused by me, looks to be OK. £25 +PP Lifeline 2000 Fire Marshall Plumbed In Extinguisher comes with cable release, 2 x nozzles and piping, bracket, clips and saftey pin. Indicator is in the green, taken from my single seater history unknown. Worth a punt for £30 +PP 7" Headlamps as used on my car untill I swaped to 5 1/2" ones. OK condition, need a wiring harness making up. £30 + PP SE flexible brake pipe set, 2 x front at 455mm total length and 1x rear at 300mm total length, some light corrosion on the end fittings but will clean up OK £15 + PP Please Email or PM Thanks for looking. Chaz. Link to comment Share on other sites More sharing options...
