Scottish Bloke Posted May 8, 2008 Share Posted May 8, 2008 Mr Shepherd and I have spent an age trying to bleed his brakes tonight, still has long pedal. New rear calipipers fitted. Just had a read on here about removing the caliper (sierra rear) to bleed. We'll try that tomorrow when we get to harewood. May need the SS friendly advice/spanner squad to assist. Cold beer will be present Bring yer tools Jocksport Quote Link to comment Share on other sites More sharing options...
cast iron Posted May 9, 2008 Share Posted May 9, 2008 Its not a problem Rich Undo the bottom small bolt, that holds the two halves together, rotate the caliper up over so the bleed nipple is above the piston or higher then when bolted up, make sure there is some contact between the piston pad and disc, then bleed. In the Westfield set up the bleed nipple is too low and you can still get a small pocket of air trapped in the top. It worked for me, and I sorted a lads car at a track day and he said his trip home was with the best brakes since he had built it Quote Link to comment Share on other sites More sharing options...
Scottish Bloke Posted May 9, 2008 Author Share Posted May 9, 2008 Its not a problem Rich Undo the bottom small bolt, that holds the two halves together, rotate the caliper up over so the bleed nipple is above the piston or higher then when bolted up, make sure there is some contact between the piston pad and disc, then bleed. In the Westfield set up the bleed nipple is too low and you can still get a small pocket of air trapped in the top. It worked for me, and I sorted a lads car at a track day and he said his trip home was with the best brakes since he had built it Thanks Mark, Nipple is at the top on the sierra rear, so the nipple is above the piston Quote Link to comment Share on other sites More sharing options...
cast iron Posted May 9, 2008 Share Posted May 9, 2008 Yep it is at the top, but not high enough. there is still room in the chamber for trapped air above the nipple. Quote Link to comment Share on other sites More sharing options...
Scottish Bloke Posted May 9, 2008 Author Share Posted May 9, 2008 OK, we'll have another go tonight Rich Quote Link to comment Share on other sites More sharing options...
