chazpowerslide Posted May 1, 2008 Share Posted May 1, 2008 4 core rad and fan, factory supplied fit as is or give a re-paint. sound condition £75 Westfield top mounted pedal box, good condition, pedals lengthened by 30mm, ready to fit. £35 ITG Megaflow Red Band air filter and blank back plate (for use with twin side-draught carbs/throttle bodies) clean and lubed ready to fit £60 2 x 7" headlamns in gloss black powdercoat, reasonable condition £20 Complete set of Westfield SE dash switches Wipers, Fan, Hazzard, Wash, Headlamps and Fog (Mini Lucas type) plus Main/Dip, Horn and Indicators (toggle type) Good condition £15 Warning lights, 4X Red, 4x Green, 2x Blue, 1x Amber £5 Braided brake lines, 2x front (450mm length) and 1x rear (310mm length) £15 2x brake line "T" peices in brass £5 Zetec Standard Clutch 2000 miles only, factory supplied. (comes with additional Helix heavy duty organic plate) £30 Zetec starter motor all working but needs a solenoid (plastic cover cracked on the back of the origional solenoid which is still fitted) £25 Screen wash pump £2 Type 9 gearbox front cover (the cover that fits over input shaft) the steel tube or "nose" has been machined off to enable the fitting of an hydraulic clutch. £10 1x pair standard Cortina hubs bare (no oil seals/bearings) £10 1x pair of Mk2 Escort 9" rear drum brakes complete (drums, back plates, brake shoes, slave cylinders springs and handbrake assembly) will require a strip and clean but all good £50 4x 60mm ram pipes for 45DCOE Weber £30 2x Ram pipe mounting kits for twin 45/50DCOE Weber (8 of 5mm nuts, 8 of springs, 8 of "D" washers per set) £5 per set. Mounting kit for twin 45/50DCOE Webers (2 of Misab washers, 8 of crushable rubber washers, 16 of cup washers) £15 Straight fuel union for 40/45/50 DCOE Weber £2 Avo alloy damper minus top collar and steel bush inserts, 12" open 10" shut to suit front of SE, SEi, SEW and SEiW £35 VDO fuel tank sender £10 Pics to follow tomorrow evening. Any of the above can be taken to Stoneleigh for collection, post will be extra if required. Chaz Link to comment Share on other sites More sharing options...
Mark Stanton Posted May 1, 2008 Share Posted May 1, 2008 QUOTE Any of the above can be taken to Stoneleigh for collection, post will be extra if required. Will there still be room for tents, food and dry clothing Link to comment Share on other sites More sharing options...
MCB Posted May 1, 2008 Share Posted May 1, 2008 Chaz, you have a PM Link to comment Share on other sites More sharing options...
Tim Reid Posted May 2, 2008 Share Posted May 2, 2008 Zetec starter motor all working but needs a solenoid (plastic cover cracked on the back of the origional solenoid which is still fitted) £25 I have an iffy Zetec starter you can take the solenoid from. Link to comment Share on other sites More sharing options...
