W1zardatWork Posted April 20, 2008 Share Posted April 20, 2008 Hi people sorry for the following simple question but i just cannot see how it is supposed to work! Bought pair of engine mounts from Westfield for new Zetec conversion. Recieved pair of mounts as in photo. One on the left great, three bolts, flat to the block. One on the right?? 4 bolts, fine found those but will sit at 45 degrees? can anyone post some photos to show it in the car? do i need an extra bracket? Quote Link to comment Share on other sites More sharing options...
chazpowerslide Posted April 20, 2008 Share Posted April 20, 2008 Yep, you need the lower pedistal mount and another rubber doughnut. Chaz. Quote Link to comment Share on other sites More sharing options...
W1zardatWork Posted April 20, 2008 Author Share Posted April 20, 2008 Aah i see? Got another rubber, take it i can get the other bit from Westfield? Quote Link to comment Share on other sites More sharing options...
chazpowerslide Posted April 20, 2008 Share Posted April 20, 2008 Yep Chaz Quote Link to comment Share on other sites More sharing options...
KenPhilps Posted May 2, 2008 Share Posted May 2, 2008 Here's a picture of mine on a new 2.0l Zetec Blacktop. I had to modify it a bit as my raceline sump doesn't sit flush with the block. its got knobbly bits! Regards Ken. Quote Link to comment Share on other sites More sharing options...
Paul Hurdsfield - Joint Manchester AO Posted May 2, 2008 Share Posted May 2, 2008 Yep thats it, the angled pedestal used to be welded to the chassis, now it's bolted on, just something else for them to forget to put in the box Quote Link to comment Share on other sites More sharing options...
Blatman Posted May 2, 2008 Share Posted May 2, 2008 They were bolted on to the early narrows too, so they've gone full circle... Quote Link to comment Share on other sites More sharing options...
pistonbroke Posted May 2, 2008 Share Posted May 2, 2008 They do make engine removal far easier Quote Link to comment Share on other sites More sharing options...
Steve Williams Posted May 3, 2008 Share Posted May 3, 2008 And make sure you lag that starter and solenoid or the heat from the exhaust headers will destroy the insulation on the windings, leaving you with starting problems. Quote Link to comment Share on other sites More sharing options...
W1zardatWork Posted May 5, 2008 Author Share Posted May 5, 2008 New Zetec is in - at last! However the RH engine mount doesnt line up with the mounting plate on the chassis Can anyone post a photo of their mount? Does this look right? Have Westfield sent me the wrong one - looks like it should be angled back toward the foot well? Any help is much appreciated Quote Link to comment Share on other sites More sharing options...
W1zardatWork Posted May 8, 2008 Author Share Posted May 8, 2008 Solved - it is due to an older chassis with a narrow tunnel, engine is further forward than on the newer cars. Cut and shut it is then! Quote Link to comment Share on other sites More sharing options...
