Just about to service my new toy ... It has done around 8,000 v intermittent miles. What should I be doing? Changing the oil? Checking spark plugs? How does one go about doing this?
Cheers!
If you've got toask, then go to a garage this time, buy a Haynes manual for your type of engine, read it in time for the cars next service and speak to the guys in your local area. My 2p worth.
change oil, maybe filter
bolt check
hub check
pads/ drums check
check levels
Mr C  :blush:  :blush:
When you change your oil always change your filter  ;)  ;)  :) tis "pennies"  :D
Cheers!
Changing Oil:
Warm up engine by driving to get new oil and filter.
Raise car on ramps / jack etc
Undo sump nut and catch oil in container.
Take off Filter and replace with new one (remembering to smear a bit of new oil around O ring first
Refill with new oil
Happy days  :t-up:
Check Spark Plugs:
Quite cheap really so may as well replace.
Take out old plug
Refit net plug
Do one at a time so that you don't mess up firing order
Jobs a good'n
Check other levels inc coolant and brake fluid and nuts that Asterix mentioned  :t-up:
Forgot to say:
Put sump plug back in before refilling with oil!  :D  ;)
Always worth checking the HT/ignition leads as well, any damage, wear or increased resistance and deffo worth replacing!!
Good stuff - thank you very much.
Judder: points a good un, unfortunately funds are tight until the wedding is out the way.
Check gearbox and diff oil also...
Cheers!
The age of the car might affect what needs to be done. Is it new? If the mileage is very intermittent, then 8000 miles would take quite a few people a good few years to cover, so it might be worth checking other stuff such as greasing the propshaft, changing brake fluid etc. which can get a bit more involved.
10 years old. Due to general paranoia I was going to check all moving parts were lubricated.
Will a FAQ search help with gearbox and diff oil, brake fluid, etc?
What engine do you have ?
zetec on carbs - assuming it is in general solid as a rock and basic mainenance (oil, water, air filters) will go a long way.
has it ever had a timing belt if the engine is 10 years old ?  ???
probably should change to be one the safe side. How can I check it?
