wilwood powerlite
just fitted the wilwood calipers all fine ,but can i reuse the bradded hose and the old nipple again
more infor required :p
not sure what info you might need powerlite calipers the old calipers were off a ford cort sorry not to sure about this my self
IIRC no I don't think you can re-use the hoses, the nipples are also definately a different thread. To be sure call Rally Design they will know and can make up replacement hoses at a reasonable cost  :t-up:
Sammy,
Just finished this upgrade last week.   :cool:
The Cortina M16s (if that what you have) have an M10 thread and the Powerlites are a 1/8 NPT.   :(
My Powerlite kit came with a male/male adapter (1/8 NPT - M10) that screws into Powerlite then I replaced the male M10 connector on the original braided hose for a M10 female swivel concave seat (Rally Design catalogue number RD1511).
I hadn't fitted one of these connectors before and found an explaination and piccies from Garry Bunn in Westfield World May/June 2005.
Just bedded the new pads and new disks this weekend and I am very impressed.
Chris
hoses need to be changed as said above.
rally design is the best place to get them .
not hard to make your own from bits .cheap too.
westfield normally metric thead .and wilwood 1/8npt.
Just remebered that when i spoke to Rally Design about sorting out the hoses they told me that if the male/male connector provided with the Powerlites was goldie coloured then it was a M10-1/8 NPT.  If is silver then it was 1/8 NPT-something else.
Just something to bear in mind. :t-up:
