chrisinoxford Posted August 28, 2007 Share Posted August 28, 2007 Gents. I purchased a pressure switch from merlin motor sport When i start my engine the display registers 10bar obviouly not correct. Do they have different ranges? my engine is a vx redtop, not sure what pressure it should be reading but 10bar is not right. I have checked wires and they are right. Any ideas? Chris. Quote Link to comment Share on other sites More sharing options...
stu999 Posted August 28, 2007 Share Posted August 28, 2007 The pressure switch *must* match the guage - or strange readings will result... Quote Link to comment Share on other sites More sharing options...
chrisinoxford Posted August 28, 2007 Author Share Posted August 28, 2007 i did receive a switch with my smiths gauges however it has a rather large body and doesnt fit. Do you know how i identify what type of swith matches the gauge? Chris Quote Link to comment Share on other sites More sharing options...
perksy Posted August 28, 2007 Share Posted August 28, 2007 i did receive a switch with my smiths gauges however it has a rather large body and doesnt fit. are you saying the screw thread on the sender is the wrong size to screw into the engine Evenin' Stu Quote Link to comment Share on other sites More sharing options...
stu999 Posted August 28, 2007 Share Posted August 28, 2007 You need to get one from Smiths that does fit, or otherwise plumb in an adaptation to allow your existing Smiths switch to fit Quote Link to comment Share on other sites More sharing options...
chrisinoxford Posted August 28, 2007 Author Share Posted August 28, 2007 the thread is fine just the very large body wont fit, perhaps i will get an adapter and move it to the other port. from memory this is a much larger diameter. chris. Quote Link to comment Share on other sites More sharing options...
Bean Posted August 29, 2007 Share Posted August 29, 2007 I bought VDO oil pressure and water temperature sender units, could have sworn my gauges were VDO but no they're Smiths. Didn't half get some funny readings. Have now replaced gauges with VDO to match senders, all good. Quote Link to comment Share on other sites More sharing options...
