Stevo Posted July 23, 2007 Share Posted July 23, 2007 Hi, Following my conversion to LSD I have a complete rear end set up for an SDV car (or a dax, locost, mk etc) This comprises of: 1x Diff (not sure of the ratio as there is no tag but can find out the approximate ratio by turning the shafts) 2x push in type drive shafts with hubs (gaiters look good and I had no bearing problems before removal) 2x drum brakes hand brake cable. The whole setup worked fine when removed and I only decided to change LSD to keep me busy during the long wet evenings! Let's say £100 local pick up only. photos to follow... Link to comment Share on other sites More sharing options...
