Man On The Clapham Omnibus Posted July 13, 2007 Share Posted July 13, 2007 Hi man on the bus, Its a Lucas alternator so yep standard fit. Okay Stu, thanks - I'll pass on that then. Link to comment Share on other sites More sharing options...
carpetstu Posted July 14, 2007 Author Share Posted July 14, 2007 bttt Link to comment Share on other sites More sharing options...
Little John Posted July 15, 2007 Share Posted July 15, 2007 Noted.......... Link to comment Share on other sites More sharing options...
carpetstu Posted July 15, 2007 Author Share Posted July 15, 2007 Okey dokey More parts............ Crank pulley with 36-1 trigger wheel professionally mounted and centered. It is spaced with a proper machined ring spacer and then bolted together ......£20 plus p&p (SOLD) Trigger sensor on an alloy bracket that bolts on the water pump mounts ........ £10 plus p&p see other listings earlier in the posts for some parts still available. Link to comment Share on other sites More sharing options...
Jenko Posted July 16, 2007 Share Posted July 16, 2007 Does the trigger wheel have the correct spacing for the standard alternator....i.e. is it a 1.6 trigger wheel and not a 1.8 with the intergral wheel.... Link to comment Share on other sites More sharing options...
carpetstu Posted July 16, 2007 Author Share Posted July 16, 2007 Jenko it is the standard 1.6 v grooved disc with the genuine ford trigger wheel piggy backed onto it. Cheers Stu (the crank pulley has been hammerited but might want a rub down and fresh paint - it depends if if bothers you) Link to comment Share on other sites More sharing options...
Jenko Posted July 16, 2007 Share Posted July 16, 2007 Thanks....In that case I don't need it :-) BUT.......... Assuming the sensor has the connector have a reasonable length of wire i'll take them (and bracket of course)...... Can pay via pay pal if you want........ Cheers. Paul. Link to comment Share on other sites More sharing options...
carpetstu Posted July 16, 2007 Author Share Posted July 16, 2007 Thanks....In that case I don't need it :-) BUT.......... Assuming the sensor has the connector have a reasonable length of wire i'll take them (and bracket of course)...... Can pay via pay pal if you want........ Cheers. Paul. Paul the sensor connector isn't that good mate. The spring clip on it doesn't work and has to be taped onto the sensor. Let me know if you want the sensor and the bracket. I will do it for £10 posted if you want it. Link to comment Share on other sites More sharing options...
Jenko Posted July 17, 2007 Share Posted July 17, 2007 OK thanks for being honest...In that case I'll give it a miss....I need a spare that I know is 100% good..... Ta anyway, Paul. Link to comment Share on other sites More sharing options...
MartinH Posted July 19, 2007 Share Posted July 19, 2007 More parts............ Crank pulley with 36-1 trigger wheel professionally mounted and centered. It is spaced with a proper machined ring spacer and then bolted together ......£20 plus p&p I'll take the crank pulley if its still available. Might also be interested in the rear crank seal carrier if you have one and the price is right. Link to comment Share on other sites More sharing options...
Chris Brook Posted July 19, 2007 Share Posted July 19, 2007 If you are scrapping the engine I will have the lifting eyes off you. How much do you want for them? Link to comment Share on other sites More sharing options...
carpetstu Posted July 19, 2007 Author Share Posted July 19, 2007 If you are scrapping the engine I will have the lifting eyes off you. How much do you want for them? Chris sorry mate there are no lifting eyes on the engine. Link to comment Share on other sites More sharing options...
Chris Brook Posted July 20, 2007 Share Posted July 20, 2007 QUOTE Chris sorry mate there are no lifting eyes on the engine. b******* Link to comment Share on other sites More sharing options...
carpetstu Posted July 23, 2007 Author Share Posted July 23, 2007 Back to the top Link to comment Share on other sites More sharing options...
