Asterix Posted July 5, 2007 Share Posted July 5, 2007 Am going to remount the bulletcam on the RAC rollbar using the cunningly designed double-interlocking-jubilee-clip method. Am looking for 2 rubber collars, to damp vibration as well as protect the cam. 1 collar will go between the rollbar and the big jubilee clip (am guessing that clip needs a diameter range of about 45-55mm, dependant on the depth of the collar) and the other collar will go between the bulletcam and the small jubilee clip (am guessing that clip needs a diameter range of about 10-20mm). Am hoping that you can get rubber collars for all sizes of jubilee clips and that they're flanged to stop slipping out of the collar. Have looked on rswww.com but either I'm using the wrong terminology or they don't do them (and I would've thought that if they exist, rswww would do them). Anybody using these? Anybody got a supplier? Thanks in advance. Link to comment Share on other sites More sharing options...
mark.anson Posted July 5, 2007 Share Posted July 5, 2007 Peter Ive protected the cam with some black insulation tape and put a small piece of high density foam between the cam and the roll bar in between the jubilee clip. A tip from rough A*** racing but its free and no vibration issues. Mark Link to comment Share on other sites More sharing options...
Mark Stanton Posted July 5, 2007 Share Posted July 5, 2007 old tyre inner tubes Link to comment Share on other sites More sharing options...
