Mike Lloyd Posted June 1, 2007 Posted June 1, 2007 Probably a daft question but I have moved the alternator (70amp zetec) to the inlet side of the engine. Which belt do I need? It is a 2.0l silvertop. Thanks Mike Quote
Doug D. Posted June 1, 2007 Posted June 1, 2007 It will depend on what alternator bracket set up you're using but mine is a 6pk900, as there is only a small amount of adjustment finding the right belt is a bit tricky, try using a piece of string around the pulleys to measure the length and then find a simpathetic motor factor who'll let lo try diffrent sizes. Quote
Kevin Wood Posted June 2, 2007 Posted June 2, 2007 I'm running a 925 on mine, which is a 2000 car with the Westfield alternator bracket and recommended alternator on a silver top. Best to do as Doug says and try and measure the length of the run. Kevin Quote
Mike Lloyd Posted June 3, 2007 Author Posted June 3, 2007 Thanks chaps. I'm using a Tiger bracket, looks like its a bit of string and a trip to the motor factors then Quote
