sedsy Posted May 20, 2007 Share Posted May 20, 2007 ewItem" target="_blank">Clicky nowt2dowidme Link to comment Share on other sites More sharing options...
Darrell O'Neill Posted May 20, 2007 Share Posted May 20, 2007 Page not responding.... Link to comment Share on other sites More sharing options...
slippy Posted May 20, 2007 Share Posted May 20, 2007 Ditto Link to comment Share on other sites More sharing options...
perksy Posted May 20, 2007 Share Posted May 20, 2007 Nope, not working Sedsy, Have you broken ebay Mate Link to comment Share on other sites More sharing options...
sedsy Posted May 20, 2007 Author Share Posted May 20, 2007 ewItem" target="_blank">Try again? dunno why it wow work... ewItem" target="_blank">http://cgi.ebay.co.uk/westfie....iewItem Link to comment Share on other sites More sharing options...
Rob Marshall Posted May 20, 2007 Share Posted May 20, 2007 No that does not work either Link to comment Share on other sites More sharing options...
Bananaman Posted May 20, 2007 Share Posted May 20, 2007 http://cgi.ebay.co.uk/ws....1830757 Link to comment Share on other sites More sharing options...
sedsy Posted May 20, 2007 Author Share Posted May 20, 2007 ewItem" target="_blank">http://cgi.ebay.co.uk/westfie....iewItem Link to comment Share on other sites More sharing options...
sedsy Posted May 20, 2007 Author Share Posted May 20, 2007 stupid bl**** thing... its in wesfield parts section Link to comment Share on other sites More sharing options...
sedsy Posted May 20, 2007 Author Share Posted May 20, 2007 Copied text from ebay Nothing to do with me This is a auction for a vauxhall 16v engine . First thing a must say is this engine is BRAND NEW autosprint build engine Second thing im not giving it away i need to recoup my money as iv have some bad luck recently ,but what you are bidding on is the dogs bits have not run this engine yet only had it a couple of weeks if intrested read on. race spec head the time has been put into this ground balanced and polished crank,arp race bolts thro out the engine lighten flywheel,3 angle valve seats tophat shims,solid lifters vernier pulleys, race spec cams, valves made from one piece stainles steel these are race spec in size too they are the biggest you can get in steel duplex valve springs omega forged high compression pistons plus comp rings bore checked etc STEEL RODS adjustable oil pressure new pump etc painted and cleaned if you read that and not impressed please dont bid .you will not be disapointed at all every thing in this engine has been replace inc all gaskets and new bearings thro out depending on carb selection and engine management you are going to get 240BHP MIN Link to comment Share on other sites More sharing options...
wacomuk Posted May 21, 2007 Share Posted May 21, 2007 http://cgi.ebay.co.uk/ws....fvi%3D1 Link to comment Share on other sites More sharing options...
mr-rad Posted May 22, 2007 Share Posted May 22, 2007 This engine was listed twice, once as a Westfield engine and once as an XE engine for sale. I bid on it when it was listed as a Westfield part but then it quickly dissapeared. Link to comment Share on other sites More sharing options...
mr-rad Posted May 22, 2007 Share Posted May 22, 2007 WDVWQQrdZ1QQcmdZViewItem" target="_blank">Rcae Spec Engine Same engine! Link to comment Share on other sites More sharing options...
