Darrell O'Neill Posted February 1, 2007 Share Posted February 1, 2007 Just spent an age looking up various torque sttingins and thought i'd post them here. If anyone wants to correct me or add to the list, please do... These are for a VX SEIW but im sure most are relevent Front Lower ball joint (maxi type) to wishbone? 28lbf ft 38Nm Front lower ball joint to upright? 25lbf ft 34Nm Upright to steering track rod end? 28lbf ft 38Nm Shock absorber bolts 30lb/ft Calipers to standard uprights 40lb/ft Hub to disc bolts 32lb/ft Hub bearing bolt 27lb/ft then slack off till slight play Rear calipers 35lb/ft Cam cover bolts 7lb/ft Quote Link to comment Share on other sites More sharing options...
a4gom Posted March 3, 2007 Share Posted March 3, 2007 A comprehensive list of all torque settings for all models would be great in this section as people are always asking for them. Perhaps one of our members from westfield could help out on this. Quote Link to comment Share on other sites More sharing options...
stu999 Posted March 3, 2007 Share Posted March 3, 2007 The difficulty is ensuring that the torques values listed apply to all models. Example... QUOTE Hub bearing bolt 27lb/ft then slack off till slight play Is not right, if you have a Westfield with the factory 'pressed steel' uprights... And of course, that we are clear exactly which fasteners the torque values refer too. Example... QUOTE Rear calipers 35lb/ft Does this apply to the caliper-carrier-to-upright bolts, or the caliper-to-carrier bolts? Quote Link to comment Share on other sites More sharing options...
Paul M Posted March 4, 2007 Share Posted March 4, 2007 Perhaps one of our members from westfield could help out on this. Or maybe not. I posted this question on the technical help section on Feb 21st. No answer yet. Quote Link to comment Share on other sites More sharing options...
