Wanting a night off from fixing the car so dusted off the "to sell" box and found...
- Jenvey 48mm TBs, pair, 1000 miles use, £350
- Jenvey Air horns 48 x 90, set of 4 £50
- TBs and horns together £375
- External Fuel Injection fuel pump – high capacity with -8 alloy fittings - second hand 1000 miles use, £25. (sold)
- 38mm chokes for 45/48 DHLA Dellorto carbs (set of 4) £25
- Injectors (duratec)- new set of 4 £50
- Injectors (Dark Green 803 cosworth) 1000 miles only £140
- Injectors (Dark Green 803 cosworth) tested good £110
Offers:
- MEMS / Emerald M3DK ECU harness plug kit
- Cam phase sensor (duratec)
- Electronically controlled thermostat (duratec)
- Exhaust Gas Recyling Valve (EGR – duratec)
- 5/16” LH thread rose joints (pair w locknuts) part# MSFL5
- 1/2” x 5/8” RH thread rose joint part# RM8T
- Pinto / Cosworth sump gasket set, new
If you want to pickup I'm just south of coventry, otherwise  there will be an additional cost for postage.
Price negotiable for multiple items etc.
Photos on request
email sgilks@netapp.com / tel 07801 028138
Help me clear some space  :p
Stuart
Hi ,if the fuel pump has screw on fittings and still works consider it sold.
I will ring later this morning.
Regards Mick.
Dibs the Air Horns Please !,
Cheers,
Stephen
2nd dibs on the pump if Mick's not intrested
Ah sorry Stuart, I see they are for the twin TB's with 2 fixing holes. I have SF's with 4 fixing holes. Thanks anyway,
Stephen
First dibs on 5/16" LH rose joints please Stuart. Message left on your mobile.
Regards,
John
