Supercharger + lots of bits
Hi Everyone
As some of you may know I'd been planning a supercharger upgrade on my Zetec but I've decided to stick with the throttle bodies and just concentrate on getting the megasquirt tuned properly and enjoying the car. I may have another go at this in the future but not right now, want to have fun instead of being in the garage :)
So - lots of pics of where I'm at and a list of the stuff on offer:
We have
1x Eaton M45 supercharger straight out of a factory delivery milage mini cooper S
2x 2.5" 90 degree elbow rubber hoses
1x Rover 600 Turbo inlet manifold with air temp sensor
1x Rover 600 Turbo Throttle Body with KN filter
4x Rover 600 Turbo injectors (not tested)
1x Rover 600 Turbo injector loom
1x Rover 600 Turbo fuel rail + pressure reg + hose/connector for other end of fuel rail
1x custom (by me) plenum chamber - fits under the w/f bonnet (needs finishing)
1x custom adaptor plate made from aluminium (about 4 or 5mm thick) for bolt pattern of rover inlet to zetec head
1x additional water pump pulley (brand new, ford item) to drive the supercharger
1x small alternator as fitted by loads of peeps on here (can't remember the type without going and looking)
1x mock up bracket for holding it under exhaust
1x mock up bracket (or could be used with a bit of TLC) for holding the supercharger on the inlet side of the engine
1x BMW gasket for output of supercharger at bottom
various stainless jubliees bought for this application
1x VDO 'turbo' gauge, I was going to use this whilst setting up and maybe after too
1x VAG 1.8T air bypass valve (vac operated) to relieve the superchager on closed throttle
various bits of hose for air bypass and gauge
3x screw in (1/4 BSP) fittings for vaccum source
1x Idler pulley from VAG 2.4 engine to help with belt coverage on the supercharger
So as you can see I've been collecting various bits and bobs to get this finished, but some things need doing before it will be a go-er for anyone, these being;
Inlet and outlet adaptor plates for the supercharger (have seen these on ebay quite cheap if you're not handy with a welder)
Possibly a decompression plate (Ferriday Engineering) depending on who you talk to and what you read
Suitable belts
Finish fabrication of inlet plenum
suitable throttle cable (or modify your own)
Charge cooler system / intercooler if you wish (again, depending on what you read this is/is-not required)
Careful fuel+spark mapping after install :D
So.... anyone up for a winter challenge and to show me up for wimping out?
Really unsure as to what this lot is worth - If I can get back what I've paid out I'll be happy, and thats £300 all in (alternator / charger / bypass / gauge / fittings / hoses / throttle body / injectors / rail / manifold etc etc)
Pics;
Call me if you need to discuss or want more info 07971 224839 or email will.legge@dsl.pipex.com
I will refrain from putting this on locostbuilders.co.uk for a few days and then after there tis fleebay :(
Will.
Will
If it doesn't sell on here, stick it on the Locostbuilders site
It'll definitely go on there...
hehehe I know - but I want to see it working in a westy :D:D
bl**** hell Will, wish I'd got the money and I'd be straight round there to take it all of your hands.
John
John
just forget the silly aeroscreen idea and get more power  :p
quite difficult to predict really, and is dependant on the pulley size too.
When I worked out the pulley sizes the stock mini one that is currently fitted to it is exactly correct in ratio terms to the extra water pump pulley that I've mentioned above - when I say its 'exactly the right size', eaton's max recommended revs for the charger is found at about 8000 engine RPM with the setup here.
BTW, I'm more than happy to sketch out how I was going to do the install (plumbing etc) if anyone is interested too.
Also - the Rover 600 Turbo injectors / throttle body were good for a 200hp (factory standard) car, that regularly got chipped to 240hp with the same injectors/TB so should be ok in this application unless you are going 2ltr (but then the efficiency of the supercharger drops anyway)
provisionally sold to 24-seven
