Lacking the means of measuring this correcly, an educated guess would be for my 120bhp zetec, 3.7 seconds.
Is this in line with with your measurements?
  • Replies 40
  • geelhoed
    12
  • Matt Seabrook
    5
  • pistonbroke
    3
  • Westfieldman
    3
Kinell geelhoed...ang on......E= MC t'power of 2.......KINELL! That would be clogging it. :p
Well actually I assumed a constant power P ans as the kinetic energy is porportional to the square of the velocity we'd expect the velocity to be a function of the square root of t. With boundary conditions that for t=0 u=0 and the 0-60 time of 6 seconds we can find this estimate of 3.7 seconds.
Did you factor in the drag increasing with the cube of the velocity (through the air not over the ground) owing to the lack of smooth flow around the bodywork?
Don't forget .....
heat of the beat =  throb of the knob , when the angle of dangle is constant !
:p
Don't forget .....
:p
Only if you "pass the dutchy on the left hand side"! :p
And I thought I could read English. Ouch, my brain hurts.
My car was clocked by Car and Driver at 4.65 seconds for 0-60. 50-70 took 2.88 seconds. Plug that into your calculator.
That's a 175 hp MX-5 donk and they wouldn't let me take the windscreen off.
No need to mock the guess, I told you it was an educated one!  :p
Aerodynamic drag in a sprint is fairly negligable the correction factor for the time for a sprint to speed V
is 1+0.4*(V/Vmax)^3 where Vmax is the topspeed of your car.
4.65 to 60 gives us a velocity function of  U = 60*sqrt(t/4.65)
So for the time to 50 you need 3.23 sec and to 70 6.33 which gives 3.1  for 50-70. So I guess we need a 7% correction for the slower acceleration off the line than modelled! Thanks Keith for the useful info!
Any others?
Oh, the Cd of a seven is around 0.7
Easily calculated(estimated) by taking the top speed (112mph) and the peak power (120bhp)
P=0.5*rho*A*Cd*U^3
rho, the density of air is about 1.2kg/m^3
Cd=2/1.2kg/m^3*120bhp / (112mph)^3/1.7m^2 = 0.68
P=0.5*rho*A*Cd*U^3
If you say so  :D
Sure I know that I am neglecting the linear and quadratic terms, but at topspeed that's seems justifyable.
