colnagowetdream Posted November 25, 2006 Share Posted November 25, 2006 http://avatars.gentlyhosting.co.uk/9294.jpeg http://avatars.gentlyhosting.co.uk/9295.jpeg http://avatars.gentlyhosting.co.uk/9296.jpeg http://avatars.gentlyhosting.co.uk/9297.jpeg http://avatars.gentlyhosting.co.uk/9298.jpeg http://avatars.gentlyhosting.co.uk/9299.jpeg Type 9 C/R, S/C gearbox (Tran X gear kit) £750 Escort prop shaft £50 Live rear axle, 3.9, LSD (will confirm by inspection) £450 5x Minilite 6x 13’s with Yoko’s, Ford PCD, offset 108 £200 2x Minilite 7 x 13 with bald Yoko’s, Ford PCD £100 Narrow body Black nose cone with mini bike indicators £125 Narrow body White (original) nose cone with old Westfield indicators £110 Narrow body white bonnet (got hole next to top air intake) £50 Escort radiator, recored with 2.8i core £50 Foot mounted rear view mirror £50 Fuel Gauge, Temp Gauge, Oil press (mechanical) Gauge £30 Carbon Dash with carbon steering shroud £60 Switches, various £30 Small motorbike style Battery, charger & mounting plate £100 4 point red harnesses (pair) £60 Standard escort pedal box £25 Pair of Cortina uprights and hubs £75 Front Spax shocks and springs £50 Rear spax shocks and springs and trailing arms £70 Narrow body main body work (white) £150 2.5 steering rack £50 Carbon cycle wings with brackets (follow profile of tyre) £80 pair Link to comment Share on other sites More sharing options...
ray5wood Posted November 26, 2006 Share Posted November 26, 2006 hi might be interested in rear shocks and stuff how old? track days milage etc ray Link to comment Share on other sites More sharing options...
slippy Posted November 26, 2006 Share Posted November 26, 2006 Here you go mate Link to comment Share on other sites More sharing options...
colnagowetdream Posted November 26, 2006 Author Share Posted November 26, 2006 Thanks slippy, I am a computer luddite at the best of times! Russ Link to comment Share on other sites More sharing options...
slippy Posted November 26, 2006 Share Posted November 26, 2006 Nee bother mate just click the image button above the box where you write your post and copy and paste the link from your gently hosting account Link to comment Share on other sites More sharing options...
Bean Posted November 26, 2006 Share Posted November 26, 2006 I'll take the cycle wings with brackets, PM Sent. Link to comment Share on other sites More sharing options...
colnagowetdream Posted November 27, 2006 Author Share Posted November 27, 2006 Gearbox details Purchased from Phil Stewart of Road & Race in Seven Oaks last September. Rebuilt by himself and done zero miles since rebuild Gearset is TranX, S/C, C/R with the following ratio's; 2.27, 1.6, 1.21, 1.1, 0.9 Russ Link to comment Share on other sites More sharing options...
JeffC Posted November 27, 2006 Share Posted November 27, 2006 what is the backspace or offset of the 6x13 minilites ? Link to comment Share on other sites More sharing options...
John Loudon - Sponsorship Liaison Posted November 27, 2006 Share Posted November 27, 2006 LOL - set number 5 Jeff? Link to comment Share on other sites More sharing options...
custardtart Posted November 27, 2006 Share Posted November 27, 2006 Hi, Have Pm'd last week ref the following: 6X13 wheels White nose, bonnet and bodywork, Did you get it or shall I send it again? Matt Link to comment Share on other sites More sharing options...
colnagowetdream Posted November 27, 2006 Author Share Posted November 27, 2006 Have checked all 5 wheel and the only thing I can see marked on the wheels is 108 which is the distance in mm from the back flange to the inner wheel rim. These wheels were off a live axle car if that clarifies things Russ Link to comment Share on other sites More sharing options...
John Loudon - Sponsorship Liaison Posted November 27, 2006 Share Posted November 27, 2006 Russ, If it helps, you can calculate what the offset by measuring the overall width of the rim and dividing by 2 and then bymeasuring the distance from the inboard edge of the wheel to the inside of the hub mounting face. The difference between the 2 measurements is the offset John Link to comment Share on other sites More sharing options...
a4gom Posted November 27, 2006 Share Posted November 27, 2006 Link to comment Share on other sites More sharing options...
colnagowetdream Posted November 28, 2006 Author Share Posted November 28, 2006 Will measure tonight Russ Link to comment Share on other sites More sharing options...
colnagowetdream Posted November 28, 2006 Author Share Posted November 28, 2006 I make the offset on the 6" wheels to be 20mm and 15mm on the 7" wheels Russ Link to comment Share on other sites More sharing options...
