mef Posted September 29, 2006 Share Posted September 29, 2006 Alloy fuel rail kit for twin Jenvey Throttle bodies, brand new & unused, middle tube requires cutting to length to suit your setup. 8mm push-on ends for fuel pipe. Includes alloy spacers, injector clips and fitting screws and cutting instructions. £50 Martin 07837 721986 Link to comment Share on other sites More sharing options...
Mark19800_0 Posted September 29, 2006 Share Posted September 29, 2006 Will this fit on Nikpro's throttle bodies mate? If so may be interested Mark Link to comment Share on other sites More sharing options...
mef Posted September 29, 2006 Author Share Posted September 29, 2006 Sorry, no, you need a one piece steel one for them, can supply one though if you want one, would be £65. Would need to know which manifold your using to get the spacing correct. Cheers, Martin Link to comment Share on other sites More sharing options...
Dave Eastwood (Gadgetman) - Club Chairman Posted September 29, 2006 Share Posted September 29, 2006 Are you sure, Jenvey supplied the three piece alloy type with my TB45i TBs' Link to comment Share on other sites More sharing options...
mef Posted September 29, 2006 Author Share Posted September 29, 2006 Yes I'm sure, the 40/45 tapered ones are not TBP45i's they are single SF units which require a specific fuel rail. The TBP45's are parallel twins which normally take a 2 piece fuel rail with the joining tube like I have available. Trust me, I know a lot about Jenvey stuff! You could only use the TBP45 fuel rail if the spacing between the first 2 individual TB's just happened to be the same as that of a single twin TB, a bit unlikely though! Martin Link to comment Share on other sites More sharing options...
mef Posted September 29, 2006 Author Share Posted September 29, 2006 But.....having just read Nikpro's advert, I cant understand what he's selling...Idon't know of any Jenvy TB pairs that are tapered...I assumed that they were the individual SF tapered units. I wasn't aware of any twin tapered TB's...in that case if they are TBP40's then Yes, my fuel rail kit will fit, but please check that these TB's are what you think they are, 40's tapering to 45's, I suspect not. Cheers, Martin Link to comment Share on other sites More sharing options...
nikpro Posted September 30, 2006 Share Posted September 30, 2006 The fuel rail will fit. The throttle bodies I'm selling are TBP40i; the part where the air horns fit are 45mm in diameter and the opening that attaches to the manifold are 40mm in diameter. They are standard fit on westfield 1800 sport models. All jenveys are like this so the same air horns can be ftted to 40mm,42mm & 45mm TBP's. They are the parralel bodies but they do taper as do the TBP42i's. Martin, you say you know a lot about Jenvey products yet even a quick look at the drawinggs on the Jenvey website shows that all TBP's of 45mm and under have a 45mm intake, hence TBP40i's taper from 45mm to 40mm and TBP42i's taper from 45mm to 42mm!. Link to Jenvey technical drawing for TB's Link to comment Share on other sites More sharing options...
mef Posted September 30, 2006 Author Share Posted September 30, 2006 Sorry Nikpro, yes you're right. This didn't used to be the case though, I have in the past sold TBP40's and specifically 40mm air horns to go with them (admittedly not for a while though) Where I was misled was by you calling them tapered, Jenvey call these parallel bodies. It's the SF's that are the fully tapered ones. It looks like Jenvey have re-vamped all their drawings and also added a fair number of new bit & pieces plus some subtle mods, it makes sense if you can use a common 45mm air horn on all TB's though. In which cas, Yes, my fuel rail kit will definitely fit, sorry about the confusion. Martin Link to comment Share on other sites More sharing options...
Mark19800_0 Posted September 30, 2006 Share Posted September 30, 2006 Can I have it the Martin? I will PM you now Mark Link to comment Share on other sites More sharing options...
mef Posted October 1, 2006 Author Share Posted October 1, 2006 Now SOLD Link to comment Share on other sites More sharing options...
