sammy Posted September 13, 2006 Posted September 13, 2006 i have the rubber o ring type and the rubber washers also but not sure were the rubber washers go ( is it under the bolt head our between the manifold and carb) thanks pic would be great Quote
bultacobarry Posted September 13, 2006 Posted September 13, 2006 assumning its twin webers You should have a paper gasket between the manifold and the head. Then there are two choices between the carbs and the manifold. 1) Injection molded plastic part with O rings inserted in either side. or 2) Alloy misabs with the rubber O rings bonded onto the the aluminuim. Option 2 is preferred from my perspective as the plastic type often crack and allow air leaks. There may be more info in the FAQ section Quote
