the_fbi Posted September 9, 2006 Share Posted September 9, 2006 I'm sure I'm not going mad. The manual says they'll be green/black and black wires for the right side indicator. I've got a green/black and black for the front right indicator, coming out of the loom with the front right headlight, where it should be, but nothing between it and the oil and water senders which according to the diagram there should be. Not got the one for the left side either. Was there a change at some point and I've got to split the the front indicators for the side ones too, or am I missing something? Its a ~2000 Megabird loom afaik. ta Chris Quote Link to comment Share on other sites More sharing options...
smithydar Posted September 9, 2006 Share Posted September 9, 2006 its a long time since i did mine but im sure the wires were there but had to lengthen them a fair bit. if they definately arent there then splice into the indicator wires and run some fresh ones. hth darren Quote Link to comment Share on other sites More sharing options...
combatsapph Posted September 11, 2006 Share Posted September 11, 2006 I'm fitting my loom at them moment - I'll get some pics for you. Here is a photo of my wiring diagram in the meantime:- http://www.amigafan2003.plus.com/19_08_06/loomdiagram.jpg Quote Link to comment Share on other sites More sharing options...
the_fbi Posted September 11, 2006 Author Share Posted September 11, 2006 Hm.. Great diagram, half of it is similar to mine, which I guess is a good thing! Need to check a bit more thoroughly when I get home. Thanks Chris Quote Link to comment Share on other sites More sharing options...
