Hi Austen, could be interested in the whole package we need to have a chat about this  :D
Will your turbo fit my cossy??
Don't listen to Rob, clearly he's till recovering from LeWomans and doesnt realise what he's saying
I want your zirconia ......!!
CASH is waiting - and you know Im close to home.
Talk to me.
Rich
PS Will new project beat your TOTB times?
Hi Richard
The turbo will fit straight on to your turbo manifold as it is a T3 flange but you will need to get it modified to run an external wastegate which is easy to do and I can get it sorted for you without a problem.
My new set up should be able to see well over 550bhp if required and should easy propell me into the 10's if I can get the traction.
Call me if you are interested on 07887 517597
Austen
  • 2 weeks later...
The head is also good for N/Asp use.
  • 2 weeks later...
I'm now thinking of selling the entire lot apart from Inlet, sump and management now.
If I cannot sell the motor I will break as seperate bits.
The bits I'm selling include
Big valve ported Zetec Head
Turbo spec cams (Area 51 spec)
Coil on plug set up and mounting plate
Block complete with crank, waterpump, oil pump, Farndon H section Rods and Aries Forged pistons.
Cast turbo exhaust manifold
Turbosmart Wastegate
T34 Turbo for external gate
Austin
Might you not be better off selling this to the fast ford boys... ???
Got several other adverts out there at the moment inc some of the Ford websites.
The problem with the Ford boys is they have no money though.
  • 3 weeks later...
  • 4 weeks later...
