SEiW Dunnel 2.0 Zetec
Westfield SEiW - Race chassis
Dunnel 2 litre Zetec giving 205bhp on twin 45 Webers
Originally built in 1997 but completely rebuilt in 2005, including completely new suspension, steering, braking system, cooling system, electrics, bodywork, seats, harnesses, instruments and gauges
Weighed in at 550kg with all fluids and half a tank of fuel
Fully set up by Procomp
Full Spec:
Widebody race chassis with IRS
Welded in RAC rollbar
Lightweight bodywork in black with detachable rear arches
Bonnet exit stainless exhaust and 4-2-1 manifold custom-made by JP Exhausts
Procomp widetrack front suspension (mainly rosejointed)
Procomp front and rear ARBs
AVO aluminium bodied adjustable dampers with spherical bearings
2.25" springs
Quickrack
Cortina uprights modified for correct Ackerman angle
Aluminium hubs
Bias adjustable brake bar
Wilwood Powerlite calipers with Wilwood pads (front)
Aluminium Golf calipers (rear)
Lightened and cross drilled brake discs
Quaife Heavy Duty Type-9 gearbox built by Road & Race Transmissions (capable of taking up to 275bhp)
1st - 2.39
2nd - 1.54
3rd - 1.21
4th - 1
5th - 0.87
Ford Sierra 3.92 LSD
Bailey Morris Prop Shaft
Stack 8130 dash
Momo removeable suede steering wheel
FIA-approved cut-off switch
Toggle switch starter
Tillet W1 low-back seats
Sabelt 4 point harnesses
Pacet Red Top fuel pump
Filter King fuel pressure regulator
Odessy gel battery
Polo radiator
Silicone hoses throughout
Oil catch tank
15" Ultralegerras with 195/50 R15 R888
MOT May 2007
Tax Feb 2007
£12,750
Mobile: 07779 607 686
Aye, lit's a cracking looking car, great attention to detail too.
Don't buy it it's cr@p...... :p
Ok it's not, it's a cracking car & is well sorted, I just don't want to lose a Cheshire group member...   :D
Good luck with whatever you do mate, this car drives superbly & has had no expense spared during the rebuild.
Cheers,
Mark.
