westy666 Posted July 27, 2006 Share Posted July 27, 2006 Hi Hugh Hopefullly you'll see these ok. The all important 42mm bore we require. A pic of the bodies as they are currently, dismatled basically and the initial respacing for a zetec manifold. And finally all the gubbins you're welcome to as I wont be needing it (if my jenveys ever turn up!) TB's, injectors, gsxr fuel rail, injector loom, tps, a couple of other electrical gizmos i have no idea about, butterflies and spindles from the secondary set, throttle cable bracket and some odds & sods spacers & springs that were fitted between the bodies before i split them up. Damian Link to comment Share on other sites More sharing options...
