mef Posted July 16, 2006 Share Posted July 16, 2006 Brand new Bosch 0580 254 909 fuel injection pump, suitable for throttle body conversions on a Westfield etc. Massive flow rate from this pump would supply enough fuel for up to 500 Bhp! Comes complete with banjo union & fitting kit for outlet connection. Bargain! £85 Martin 07837 721986 Link to comment Share on other sites More sharing options...
Blatman Posted July 16, 2006 Share Posted July 16, 2006 If this has -6 fittings at both ends then I want it. First dibs please subject to the fittings question... Link to comment Share on other sites More sharing options...
mef Posted July 16, 2006 Author Share Posted July 16, 2006 I can supply it with a -6 outlet fitting if required but the inlet would normally want to be bigger than that anyway (low pressure side) It has a 1/2" "push-on" fitting that is integral to the case so it can't physically be altered. The alternative would be to make up an adaptor using a very short length of hose to whatever fitting you want. My own car uses a -8 on the inlet side. Cheers, Martin Link to comment Share on other sites More sharing options...
Blatman Posted July 16, 2006 Share Posted July 16, 2006 OK. I already have a pump with the push on inlet fittings, so I don't need another one! Thanks anyway. Link to comment Share on other sites More sharing options...
mef Posted July 16, 2006 Author Share Posted July 16, 2006 OK Blatman, the 909 pump has push on fittings, you need a 949 unit that has a metric screw thread on both ends, that way you can fit adaptors to -8 & -6 etc, only thing is price is about double! Cheers, Martin Link to comment Share on other sites More sharing options...
Bazzer Posted July 17, 2006 Share Posted July 17, 2006 The Bosch 0580 254 044 has screw on fittings and can deliver a bit more fuel than the 909. Its very good at maintaining flow at higher pressures so is favoured on turbo engines. Only problem is they are £165 + VAT they do come up on ebay a fair bit though. Cheers Bazzer Link to comment Share on other sites More sharing options...
mef Posted July 17, 2006 Author Share Posted July 17, 2006 Bazzer, you are quite correct, the 044 is the ultimate Bosch pump but the 979 that I use on my Subaru is less expensive and adequate for 300Bhp and has screw threads like the 044. The 909 I have advertised is more powerful than the 979 but only has the push-on inlet fitting. Martin Link to comment Share on other sites More sharing options...
