scruffythefirst Posted July 10, 2006 Share Posted July 10, 2006 Make me an offer for any of the below, will all be going on ebay in a week or so. Can provide photo's of any of the below. Racetec fuel level guage, new fitted but done zero miles. 4 brand new, boxed bosch 803 injectors, full part number is 0280150803. Remote oil filter and Braided oil hoses. Hoses are 21" and should fit most cars with a screw on filter, fitted my cosworth fine, brand new but fitted to car for a short time. Has done 0 miles. Standard Pinto sump. Slight dent in bottom and could do with a clean. Pair of Dax or other kit car polished stainless steel sill protectors, been notched already but can be trimmed to 558mm and 555mm Westfield Astrali sva steering wheel hub, 102mm ish pcd and splines to fit standard westfield column. Black Silicon hose 60mm dia, 45 deg bend 18cm legs Black Silicon hose 60mm dia, 45 deg bend one 12cm leg one 7cm leg Blue silicon hose turbo to intercooler hose with D/v take off - 60mm one end ~ 80mm other. 60mm dia hose joiner in aluminum Cosworth 2wd inlet plenum and inlet manifold, blasted and painted in blue 2 pack paint with clear sparkle laquer, absolutely mint condition 2wd cosworth inlet elbow, modified by dax, painted in blue 2 pack and sparkle laquer. ARP 4x4 cosworth rod bolts, still in original wrapper (packet has peeled slightly) Used standard 4x4 cosworth pistons, slight marks on top of one. Webber L8 cosworth 4x4 ecu with stage 3 chip for 803's and t3. Cosworth Ign amp Group A cosworth coil 4x4 Cosworth sump including driveshaft, good condition could do with a clean. 2.0l vectra calipers, ideal for 308mm brake conversion on a cavalier. Vauxhall cavalier 5 stud rear hubs, ideal as part of a 308mm brake upgrade. 4x4 Cosworth 200 engine block. Standard bore, very little ridge, mainly just combustion build up. Slight crack in one head bolt thread. Easily repaired by engineering shop. Pinto crank, from A reg 2lt auto. pinto high compression pistons and rods, from A reg 2lt auto. 4x4 Cosworth alloy engine mounts, good condition 4x4 cosworth oil filter extension including bolt and nut, good condition 4x4 cosworth breather kidney box and breather pipework, good condition 4x4 cosworth power steering pump, maybe slight issue with one of the connections, easily resolved if your replacing yours. 4x4 cosworth alternator and bracket and polyv belt tensioner, good condition. 4x4 cosworth plenum cover, good condition, could do with a clean. 4x4 cosworth TPS 4x4 Cosworth engine loom, been unwrapped to copy but can be re-wrapped. Link to comment Share on other sites More sharing options...
smithydar Posted July 10, 2006 Share Posted July 10, 2006 do you still have a car left after all that lol darren.. Link to comment Share on other sites More sharing options...
scruffythefirst Posted July 12, 2006 Author Share Posted July 12, 2006 Bump, going on e-bay as soon as I can work out how Link to comment Share on other sites More sharing options...
Bazzer Posted July 13, 2006 Share Posted July 13, 2006 Do you know the flow rate of the injectors ? Cheers Bazzer Link to comment Share on other sites More sharing options...
scruffythefirst Posted July 13, 2006 Author Share Posted July 13, 2006 382cc / min i think. Link to comment Share on other sites More sharing options...
Liam Posted July 14, 2006 Share Posted July 14, 2006 Why didn't you build two Hugh Link to comment Share on other sites More sharing options...
scruffythefirst Posted July 14, 2006 Author Share Posted July 14, 2006 Got the second on the go as we speak, suspensions on, brake lines in, loom in etc etc Link to comment Share on other sites More sharing options...
fatbaldbloke Posted July 15, 2006 Share Posted July 15, 2006 PM sent Link to comment Share on other sites More sharing options...
scruffythefirst Posted July 21, 2006 Author Share Posted July 21, 2006 Bump again Link to comment Share on other sites More sharing options...
