Azzacat Posted May 18, 2006 Posted May 18, 2006 If i need one? Can you point me in the direction of a supplier of a cheap low pressure fuel filter with 15mm ends, i want it to go between the tank and the pump, just to protect the pump a bit, i already have a Bullet high pressure filter up the front pre injectors,, On Another note, when will i be able to assosiate my Username with my membership number? does it really take 21 days? Cheers! Quote
Major Stare Posted May 18, 2006 Posted May 18, 2006 Welcome. Are you sure you need a low pressure filter, your topic says pre-injection filter? If you are running carbs you will need a low pressure filter which are very cheap... Burton/Car Builder Solutions/local car shop etc. If you are running injection you will need a high pressure filter, iam using a vauxhall astra item. If you are running injection, what car is it, swirl pot etc ? HTH Quote
