Mitchamidilly Posted May 10, 2006 Share Posted May 10, 2006 I have tried a search and could probably put together a kit myself eventually but wondered if anyone has a kit of silicone hose bits I need to plumb in the waterail to the polo rad? I am installing a heater and do not plan to use a header tank. I also have the ally pipes supplied with the standard Westfield kit. Still looks like a few joins are needed. For example 2 x 90deg elbows would be needed out from the rail in order to include a 90 deg twist and point forward towards the rad. Is there one part which does all this without joins? Sorry if it sounds obviuos but this is the first time I have donde this hense newbie post Cheers, P.S. Need to update my pic! Car is rolling and will be PO red. Quote Link to comment Share on other sites More sharing options...
davew Posted May 10, 2006 Share Posted May 10, 2006 I did this recently very easy to fit. You will need the following. 1 x 8MM FLEXI SILICONE BLUE HOSE - for overflow 1 x 32MM FLEXI SILICONE BLUE HOSE for joining system to rad 1 x 45/32MM 90 DEGREE REDUCER HOSE - for water pump 2 x HOSE JOINER 1:1/4'' X 12'' to connect between water rail to rad hose and water pump to rad hose 1 x 32MM 90 DEGREE BLUE HOSE ELBOW - for water rail Plus hose clips I do not have a heater but this would just require a couple of additional flexi hoses. Also have a polo radiator and no header tank. System works very well but you need to drill a 3mm hole in thermostat to allow gradual warm up but this is easy. Hope this is of help. Quote Link to comment Share on other sites More sharing options...
davew Posted May 11, 2006 Share Posted May 11, 2006 Forgot to add all available from merlin motorsport. Quote Link to comment Share on other sites More sharing options...
