scott beeland Posted May 22, 2006 Posted May 22, 2006 That do you John? Quality is excellent and it sounds great
John Loudon - Sponsorship Liaison Posted May 22, 2006 Posted May 22, 2006 Yes. Thank you Scott. BTW - try using Swarfega instead of your cycle wings. It works better
scott beeland Posted May 22, 2006 Posted May 22, 2006 Oi...That's my new camouflage flip paint job on my cycle wings....... You don't like it then?
Westy1700 Posted May 22, 2006 Posted May 22, 2006 any more close up pics of the mounting to rear of chassis/body ?? I take the specs will satisfy SVA ? Cheers
Paul Ash Posted May 24, 2006 Author Posted May 24, 2006 OK - Final call for Silencer Bulk Buy. The list so far. 1. Blatters 2. Dabar 3. Dibbly 4. D.Wilkes 5. Higgsti 6. Steve_m 7. Deano1 8. Gooders 9. Mat1800 10. Hogman 11. Chasf42 12. ivor.rankine 13. rickslack Dated 24/05/06 22.00 If anyones missing or not taking part in this offer let me know. Otherwise expect to receive an order form shortly Paul
MAT1800 Posted May 26, 2006 Posted May 26, 2006 Anyone else going for one of these with a 1800zetec / madness kit... Wanting to fit onto a standard WF manifold? ? The reason I ask was, perhaps if you want to Email me we can compare measurements... Of the exhausts! after this weekend. Just thinking it might help.... Cheers, Mat.
chasf42 Posted May 26, 2006 Posted May 26, 2006 Anyone using this with a VX low exit exhaust on a widebody that I can compare dimensions? Anyone proposing to use this with swept wings?
Gooders Posted May 26, 2006 Posted May 26, 2006 Hi Mat I am fitting the Simpson Can onto the standard Westfield manifold on a 1800 Zetec and i would love to check my measurements to yours Gooders
higgsti Posted May 27, 2006 Posted May 27, 2006 any one got a megablade with standard manifold there fitting one of these to compare measurements
MAT1800 Posted May 31, 2006 Posted May 31, 2006 Hi Guys, I'll post up my measurements on here for now.... Just to keep you all amused. As I can't email pictures through the boardroom, although it might be easy to dsicuss via PM ? I dunno? Any how from the following picture... I came up with the following measurements... D=48mm , A=650mm, E=30mm, F=140mm max. Although these are more or less based on what is there, not the biggest I could have... also I'm not sure about the angle of the silencer, in relation to the side of the car, as you should all know.. yet I've clearly shown in the piccy below. The exhaust pipe follows the line of the bodywork at the front, then there is about a 12degree bend in the pipe just before it enters the silencer... So are the simpson pipes straight all the way? I seem to recall seeing a picture where they had fitted on to a zetec and it was striaght? Also I'm not sure how BIG i could make it, IYSWIM.... So how are you other zetec guys doing this? ? PM's sent.... please reply (either here or PM) Cheers Mat. *** All images problems sorted, don't know why don't know how... ***
Paul Ash Posted May 31, 2006 Author Posted May 31, 2006 Dibbly Can they do one with a Cat? (new build) 7" Diameter brushed stainless can with stainless sports Cat internals. Cost of CAT version £410 + VAT
Paul Ash Posted May 31, 2006 Author Posted May 31, 2006 Price on titanium can 7"Diameter can upto 29" long. Stainless spun ends, repackable. Outer tube in titanium, natural finish, internal diameter to your spec. stainless tailpipe with rolled end. £ 360 + VAT
