Omex Rev Limiter & Launch Control
Major Stare
Omex Rev Limiter Clubman with Launch Control.
Complete with instructions.
Launch control switch has been cut off the lead, but it would be easy to connect another switch.
£40.00 inc postage to UK
Details............
The Omex Rev Limiter Clubman with Launch Control features an extremely smooth rev-limiting action and a selectable hard or soft cut.
It also has an auxilliary rev limit which is operated with the supplied waterproof switch that can be mounted on the stearing wheel or the gear knob.
Set separately to the main rev limit, the auxilliary limit is used at the startline to prevent wheel spin or the engine 'bogging down' enabling very consistant results.
The unit is suitable for most 2, 4, 6, or 8 cylinder single coil engines that use points, electronic, or ECU ignition.
Link to comment
Definitely sold :D
Link to comment
