What is the largest 4 Cyl engine available?
There's some pretty big 4 pot diesel engines, you can run 3 or 4 bar boost on diesels quite easily, would make for an interesting gearbox :D  I think Iveco have a 4 litre unit.
Or how about a turbo Duratec, I read on the darkside that IIRC Ammo has a 2.5 conversion . . . all alloy so low weight, would be good enough to make interesting power and be reliable.
Why stick with 4 pot ?  ???
  • Replies 38
  • RS WST
    6
  • Blatman
    4
  • hilux
    3
  • scruffythefirst
    3
I've come accross the 3 Litre 16v 4 cylinder Porsche engine as found in the 1988 944 S2 and the 1993 968 CS. All alloy and I can imagine it will be well designed too.
:t-up:
Wasn't there a 944 Turbo anyway?  ???
I think 3L is about as big as it gets, bejond this the flame front across the piston is too slow to make them of any kind of use to modern cars. Even porsche strggled with this for a while I remember reading in a book recently.
Think thats as big a 4 cylinder car engine you're going to find.  Never thought of it before but I bet it would make a fine engine for a Westy..... if it fits.
It would indeed, over 330 bhp easily with an uprated wastegate and remapped chip.............
Problem is its canted over and although compact is low (hence the 944 styling but is wider)
Some colleagues with 3 litre blocks and longer strokes via 2.7 crank are running 420 bhp (which is nice) and they handle the power and handle superbly also.
Note all 944 951 968 derivatives are ostensibly the same engine ie: half a 928  :p
I can get you dims if you like but the engine and boost management are a complicated nightmare.So if you are researching its best to go down the route of an independent ECU and loom.
I`d recommend the non turbo derivative as the boost is sensational (300+ bhp equates to sub 5 secs to 60 in the 951`s) but would deffo light the wheels up in a Westy
My 951 engine bay
Personally 200 bhp available `relatively` cheaply from a VX XE is the way to go.
I`ve had huge grunt/torque in kit cars and you do not need much more than 200bhp in a Westy.
To go a different route is achallenge but expensive, rewarding but for what reason? What will the car do differently except sound different.
What about RX8?
3 litre block plus 2.7 litre crank and various pistons gets 3.2 to 3.3 litres and 420 bhp plus  ;)
I know as I`ve driven one   :p
Are 2.5 litre Ford Duratecs with us yet ?  Bound to be a good choice in years to come, just for tuneability and availability and they do fit.
What about a vr6, v6 or straight 6?
How would the 3 litre engine react to turboing?
Would it rev well enough.
Would the engine be upto the power?
Only thinking of using the head and block, the inlet, exhaust and loom would be e-bay'd
What other exotic 4 cylinders could be an alternative?
Anything with a pole and woman conected to it....hang on.... EXOTIC sorry....
There are some 3 litre 968`s that are supercharged
Just another thought, how about the 2.5 from a late E30 M3?  Know nothing about them but worth a look.
Judging from the price of spares even on my lowly 2.5 944 I'd say that it could be potentially a very expensive way to go should you decide to tune it whereas a lower capacity ford unit may well have more options but would inevitably be more common. Lovely engine mind.
not quite 4 pot, but have you thought about the ovlov T5R motor ??
full ally engine, ladder mains, massive ammounts of reliable power available and you can pick them up cheap !!
