These any good:
1QQcmdZViewItem" target="_blank">http://cgi.ebay.co.uk/RACE-X-....iewItem
Sam
  • Replies 54
  • Sam
    15
  • Blatman
    11
  • Chasmon
    10
  • kevip6
    5
I was told the same thing by Westfield ???
I assume the factory built cars rely on this filter as the pump pre-filter?   Is that enough of an assurance though ???
It should be, but I always err on the side of caution when comparing a 20 quid filter with a 100 pound fuel pump...
These any good:
Sam
Not for injection...
That's the type I have on both my Westies they are not cheep but its better than trashing a pump as Blatman has said.
So would these fit between the tank and the pump in addition to the filter between the pump and the fuel rail?
Or would one of these make the other filter redundant?
As far as i know there needs to be a filter between the tank and the pump.
That was all i was planning.
I always have a pre and post pump filter. Some folk will say that one pre pump filter is enough. I have no evidence to suggest that just a single filter won't be enough, but I choose the belt and braces approach.
And FWIW, I use a Coopers fuel filters from Partco. I don't have the part number to hand, but last time I replaced them, they were 11 quid each, complete with -6 fittings in an ally body. Can't go wrong...
Looks like you have another job to do Kevip, I'd wait until you've done the SVA first though unless you fancy ripping you fuel pump out now?
Tigger
Ha Ha, I think i will tigger!
I don't think they're ever truely finished anyway are they  :D
Here is the westfield filter...
So presumably, that level of filtration is enough for the Westfield supplied injection pump.
Graham.
But i suppose another inline fuel filter would not hurt.
More money to spend though!!
Sam
It definitely won't hurt, here are mine...
Graham.
Thats what I used on my injection system not cheap but will do the job! like blaters say's no sence in messing around when your talking £150.00 pump. :cool:
Hi I contacted Glencoe for a quote for a filter-pump-filter-regulator and they came up with an all in price of £248.65 delivered.
Bullet A6 filter £52
Pump £120
GM filter £3.82
Adjustable regulator £46.80
Hose & misc £3.20
All minus 10%, thing thaat struck me was how expensive the Bullet filter is. Is this the pre or post pump filter?
Surely OEM filters are cheaper an would be suitable?
I'm considering using the XJS pump I have in the garage or getting something off a VX, but I want all new filters.
What ones do you use Blatters?
C
