Vauxhall XE 2nd/oil/scavenge/dry sump/pump thing
As the title says :)
Well, okay, I'm not entirely sure of the workings of this, never having used it, but I believe it is a secondary oil pump driven off the water pulley allowing you to have a secondary reservior of oil to ensure a constant supply. It has an oil in/out (to draw and return from secondary tank/supply) all ready with nice shiny Mocal fittings. For fitting to a Vauxhall XE engine. A sort of not dry sump but kind of replacement for it thing.
Currently taking up room, call it £40inc delivery and perhaps could be the cheapest 'dry sump'esque system you'll fit.
graeme@fluke-motorsport.co.uk/07747 60 60 66
Cheers,
Graeme.
Courtesy of PeterW -
It looks like a Swindon dry sump pump that replaces the ali oil pump cover on the XE.  Seems to be lacking the drive shaft & pulley.  My sons car has one of these driven by a toothed belt from an extra pulley mounted to water pump.
Pete
:t-up:
