dern Posted February 15, 2006 Share Posted February 15, 2006 I'm likely to only have one coil on my v8... right? Thanks, Mark Quote Link to comment Share on other sites More sharing options...
Blatman Posted February 15, 2006 Share Posted February 15, 2006 Is it carbs and OEM ignition, or has it been converted to Mapped ignition and/or TB's? If it's on carbs and a dizzy, you are likely to have just one. If it's mapped/dis/injection etc, you may have more than one. A photo of the inside of the engine bay would solve it quite easily.... Quote Link to comment Share on other sites More sharing options...
dern Posted February 15, 2006 Author Share Posted February 15, 2006 Is it carbs and OEM ignition, or has it been converted to Mapped ignition and/or TB's? If it's on carbs and a dizzy, you are likely to have just one. If it's mapped/dis/injection etc, you may have more than one. A photo of the inside of the engine bay would solve it quite easily.... It's on a carb and a dizzy and this is the only picture of the engine bay I have on me... ...the reason for the question is that I've found an armtech speed shift box on ebay that I want to bid for. It gives change up and change down lights as well as a rev limiter and a speed shift system. One of these things is designed for a single coil and one for a twin coild system. I'm not interested in the speed shift system and am assuming I can disable it and basically only want the thing if it goes for not much money in order to give me a shift light. Thanks, Mark Quote Link to comment Share on other sites More sharing options...
Blatman Posted February 15, 2006 Share Posted February 15, 2006 Where the 8 ignition cables disapear under the nose, they end up at the distributor. The 9th lead will go to a coil. I'll stick my neck out and say you have but a single coil under there somewhere. Follow the 9th lead for the answer... Quote Link to comment Share on other sites More sharing options...
dern Posted February 15, 2006 Author Share Posted February 15, 2006 Where the 8 ignition cables disapear under the nose, they end up at the distributor. The 9th lead will go to a coil. I'll stick my neck out and say you have but a single coil under there somewhere. Follow the 9th lead for the answer... I'll have a look when I get home... just wondered if the answer might be "don't be daft, of course you only have one coil" and I could bid away with impunity It turns out the seller doesn't know which model he is selling anyway Thanks though. Regards, Mark Quote Link to comment Share on other sites More sharing options...
