Spire Posted February 14, 2006 Posted February 14, 2006 Just about to purchase some parts for my Zetec engine and I got quotes from local motor factors and ford dealer. Factors Ford Water Pump £25.79 £49.71 Timing Belt £16.54 £35.60 Head Gasket Set £33.39 £69.69 Head Bolts £6.90 £28.10 all prices + VAT Motor factors have been around for a long time and are a large company. Do not know make of parts. Always bought genuine dealer timing belts in past. Just wondered what your views are. Thanks Quote
ChrisF Posted February 14, 2006 Posted February 14, 2006 I always buy genuine parts were possible and if it's a specialist part, I always use the best. Most westfields are driven to extreme...well mine is anyway and I only relay on a the best quality parts to keep it together. My car has had over £20k of development and I won't compromise the build quality on cheap parts. This is IMHO and others may disagree...but you pays your money and takes your choice Quote
stu999 Posted February 14, 2006 Posted February 14, 2006 IMHO, it does depend on the brand at the factors. For example, if the timing belt is a 'Gates', then chances are they also make them for Ford - as they do for a lot of other manufacturers... Quote
Blatman Posted February 14, 2006 Posted February 14, 2006 Same as Stu. If the "pattern" part is made by the same company that make it for the OEM, then use it. If there is a doubt, then OEM every time for critical parts like timing belts and cooling/oil system etc. Quote
S8ight Posted February 15, 2006 Posted February 15, 2006 have fitted literally hundreds of pumps, belts, gaskets etc, maybee a few of them have been 'genuine' parts. if you use a decent make you will be fine. one thing to bear in mind about 'genuine' parts, when the car companies want bits making, they get them made by the company that comes back with the cheapest price Quote
Blatman Posted February 15, 2006 Posted February 15, 2006 one thing to bear in mind about 'genuine' parts, when the car companies want bits making, they get them made by the company that comes back with the cheapest price They have to be up to the OEM standards though, so whilst the reality is they are without question built down to a price, no-one could suggest that the manufacturers don't thoroughly test the parts fitted to their vehicles during developement. Quote
Mark B Posted February 15, 2006 Posted February 15, 2006 Just about to purchase some parts for my Zetec engine and I got quotes from local motor factors and ford dealer. Factors Ford Water Pump £25.79 £49.71 Timing Belt £16.54 £35.60 Head Gasket Set £33.39 £69.69 Head Bolts £6.90 £28.10 all prices + VAT Motor factors have been around for a long time and are a large company. Do not know make of parts. Always bought genuine dealer timing belts in past. Just wondered what your views are. Thanks I'd recommend a cam belt kit if it's going onto a used engine, the tensioning pulleys on a zetec are plastic & should be replaced at cambelt time. A kit is approx 70 quid. A mate had one disintegrate on him last week, he was lucky though & the engine was fine after a new belt kit was fitted, but it's luck of the draw.... Echo what the other say regarding the manufacturers, if it's gates, you're fine, otherwise ford may be a better option. Cheers, Mark. Quote
Paul M Posted February 15, 2006 Posted February 15, 2006 Parts from a recognised quality manufacturer such as Gates Quinton Hazell will be fine. You don't think Ford actually make gaskets, belts etc themselves do you ? Quote
Spire Posted February 15, 2006 Author Posted February 15, 2006 You don't think Ford actually make gaskets, belts etc themselves do you ? Obviously, I was only asking to see what members past experiences were with factored parts against dealer parts before making a decision on what to get, £100 saved here means £100 more to spend on the next part Quote
jeff oakley Posted February 15, 2006 Posted February 15, 2006 Okay lets clear up some doubt, all the parts supplied by car makers are made by other companies for them to their own specification. In the aftermarket those same companies will supply the same product without the OE label at a cheaper price. So a quick list is as follows LUK clutches Gates timing belts SKF bearings waterpumps AC delco, bosch, rotating electrics TRW (lucas) braking products Delphi (the old ap ) steering suspension etc Timken bearings AE engine parts Mahle Engine parts Ferodo Mintex Valeo rads and rotating electrics Now to complicate things some other companies are reboxers of product made by OE suppliers, lots of wheel cylinders are made in italy to OE spec and are then sold here, for example, reputable reboxers are Firstline who have excellant quality control, there are others I would trust and many other well known brands I would not trust. The company I work for supplies every motor factor in the country with parts, except those who we won't for commercial reasons and supply £millions to the aftermarket with little warranty issues. There are cheap brands available from China and India but if some one offers you a wheel cylinder for a couple of pounds ask yourself how they could have made it for that money and shipped it halfway around the world? If you buy from most reputable motorfactors they will be able to tell you if the parts are from an OE supplier scource if they are unable to do so think twice or email me. Quote
pistonbroke Posted February 15, 2006 Posted February 15, 2006 I get service parts from Motoquip dealer , trade prices , never a prob and seem to be decent kit . Quote
jeff oakley Posted February 15, 2006 Posted February 15, 2006 Yep, Motaquip ok they are Peugeots all makes programe so bought mainly from OE spec companies and reboxed into their livery. Don't know who makes their rubber products but I personnaly would always fit Gates. Quote
CrashBangWallop Posted February 15, 2006 Posted February 15, 2006 This would make a good 'sticky' list of DO's and DONT's if the list was to grow a bit Neil Quote
