Steve20 Posted December 15, 2005 Share Posted December 15, 2005 Could one of you SDV guys measure the distance from the steering wheel boss to the face of the dash for me please. Ideally what I need to check is top most dimension (rear of boss to dash) which on mine is 40mm Reason for asking is that it looks if it will be difficult to remove the ignition key with my column positioned as per the SDV build manual supplement. Cheers Steve Quote Link to comment Share on other sites More sharing options...
deano.1 Posted December 15, 2005 Share Posted December 15, 2005 I would measure mine for you but i used a standard dash and a column from Westfield as i thought there would be a couple of issues with the sierra column, one being the one you have mentioned Quote Link to comment Share on other sites More sharing options...
yellow peril Posted December 15, 2005 Share Posted December 15, 2005 Hi Steve, Just finished? my SDV build. Mine measures 42 mm. Not experienced any problems getting key in or out. Regards Jeremy Quote Link to comment Share on other sites More sharing options...
