tonyg Posted October 22, 2005 Share Posted October 22, 2005 Zetec Engine - Right Hand engine mount is fixed by two M10 20mm bolts and one M10 x 60mm bolt with a spacer. With the 60mm bolt tightened all the way in, the spacer (approx 20mm) is still not tight between the Monting Bracket and the engine block. Anyone know what size this spacer should be ? Thanks. Quote Link to comment Share on other sites More sharing options...
Steve20 Posted October 22, 2005 Share Posted October 22, 2005 30mm Steve Quote Link to comment Share on other sites More sharing options...
Peter M Posted October 22, 2005 Share Posted October 22, 2005 If i remember correctly the alternator mounting bracket is sandwiched between the engine mounting and block and this is the "spacer" Peter Quote Link to comment Share on other sites More sharing options...
Steve20 Posted October 22, 2005 Share Posted October 22, 2005 Correct, the 30mm measurement I have just taken was the thickness of my alternator bracket (Dunnel) Quote Link to comment Share on other sites More sharing options...
