reliable?
iv just sat through most of my break at work listening to some "friends" prattling on about how ill hate to own a westfield and that they cant wait to see my face when it breaks down over and over again.
so how often does everyones westfield break down/need work ,and so iv got a rough guide as to how good the cheaper ones are, how much did it cost you to buy (if you dont mind answering)
  • Replies 31
  • goaferboy
    4
  • Blatman
    4
  • jak
    2
  • KerryS
    2
Mine has been on the road 6 weeks and done 850 miles all OK so far  :t-up:  :D  :D  :D .  Got insurance limited to 3000 miles a year- might need to increase that  :bangshead:  :)
John.
i personally cant wait to see their faces when:
A: i refuse to give them a lift anywhere in it
B: i refuse to wait for them if their ever following me in their cars
2001 VX SEIW.
2300 miles since april......
on my third engine now, but what the hell :D:D
does it break down?...... yep at times, do I care? not at all :laugh:
skint myself to buy it, been skint ever since :D and loving ever mile....
my last car i had (1800 zetec seiw) did 8000 miles in 9 months and  the only  problem i had was putting a rather large hole in the sump. :arse:  :bangshead:
I got mine earlier this year...1600 crossflow...slightly above £5k....done about 2,000 miles this year....its not broken down....lost a rear light lense the only problem.
Not been in a garage....just tightened a few bolts and checked levels and thats it.
Most pre-90's car use to stop on 'ignition type' failure....so fit a decent electronic system..... if its got twin webers get them set up by a specialist [then dont touch]... make sure coolant system is efficent.
For 'smiles per mile' it beats anything....and am a devoted Land Rover anorak...... just get one.
If I was starting again would go for a Pinto SEiW
1998 Vx wide body. Only breakdown was self induced. It's as reliable as my diesel Mondeo, but a bit less boring...
Zetec Live axel wide body, cheap for year, never broke down, just broke.
SEiGHT 4.6 Efi V8 broke down once on the C2C due to after market rotor arm bought genuine part bin fine since covered 14,000 miles in it since I bought it in 03 right up to the point when I blow the engine up at Mallory! now sorted and on its way over the Atlantic in a conatiner ship for a 3400 mile tour of the USA Houston to Frisco....not sure if I've mentioned the tour before!! :p:p
Buzz
Buzz
thanks for all the help. im not too fussed about the occasional breakdown since the car i currently drive (golf mk2) breaks down quite a bit in the winter (its at the garage as i write this). its just id rather not spend a lot of money on a car thats going to sit in a garage when i could be out posing :cool:
definately filled me with a bit more confidence in them anyway.
The cars aren't inherently unrelaible. It's what people do to them that makes them unreliable...
C: Nothing comes Close for the Money
D: You Should Never be Late for Work again, Unless it's a Sunny Day and You go for a Blat istead of Going to Work  :devil:
E: It'll Turn Heads just about Everywhere
F: Join the Club, and Be a Member of the Best and Most Friendly Owners Club there is.....
Oh yes. Drove past Harrods in mine on Bank Holiday Monday. There was a Bentley Coupe thing behind me, and a Merc SL55AMG in front. No-one was looking or waving at them... :D:D:D
It's as reliable as any other car out there, but the silly grin on your face when you drive it is priceless  :p:p
Had mine 2 years .
1800 Zetec Seiw
Faults =  Broken Speedo
Breakdowns = 0
At the end of the day its gonna be more reliable to a certain point as it has no AC/EW/ES/PS/ABS/ or the other 101 names for creature comforts.
What most of them have is an engine from a mainstream car. And unless you have no mechanical sympathy it should run and run and run :)
Persil
