stevo oakham Posted August 22, 2005 Share Posted August 22, 2005 will a standerd zetec fuel pump be ok for my westy or witch one should i use thanks Quote Link to comment Share on other sites More sharing options...
Eddy5 Posted August 22, 2005 Share Posted August 22, 2005 Need more info really, like what engine your intending to use (I presume Zetec) how much power you'll want, injection or carbs etc. Quote Link to comment Share on other sites More sharing options...
Blatman Posted August 22, 2005 Share Posted August 22, 2005 If you are keeping the standard injection or using throttle bodies, it should be fine. If you are going to run carbs, it won't be... Quote Link to comment Share on other sites More sharing options...
michaelcoombs Posted August 23, 2005 Share Posted August 23, 2005 I have a standard escort Zetec pump on a Zetec with throttle bodies and it is fine even with the boost in fuel pressure to 3bar (different regulator).... you can even use the attached fuel sender with a little clever soldering. Quote Link to comment Share on other sites More sharing options...
