whats a 'pinto' eactly?
Excuse my ignorance - whats a pinto engine? Some sort of ye olde ford unit predatinga zetec?
ta.
  • Replies 36
  • geofff
    5
  • funbobby
    4
  • scruffythefirst
    4
  • Blatman
    4
its a cortina or sierra engine (single cam 8v)
I believe it got the name from the car it was used in, a american ford pinto.
righto. thanks. easier or harder to maintain than a newer zetec? I suppose a 1800 zetec can be serviced like any other ford?
Paul,
Iff you have the possibility go for a zetec 1800. The pint is okay but a heavy lump. The zetec is more or les lightweight and nowadays reasanoble cheap to get.
Watch for an Escort zetec. A Mondeo zetec you'll have to change the flightwheel and clutch, waterpump, for an Escort clutch and waterpump. New camshafts in it and you'll have 130  - 140 bhp.
Look on other treads in this site. A lot is writtten about it.
Marcel
Both pretty easy to maintain, pinto would require a little more work (changing oil spray bar yearly etc) but both are pretty simple.  I would have thought any garage would have no problems with either engine.
And if you go for a Zetec, get a 2 litre...
Oil spray bar ??? What am I not doing?
Oil spray bar has me raising an eyebrow too. The only one I can think of that is removable is fitted to a Cosworth. It is an integral part of the pick up pipe, and sprays oil on to the underside of the pistons. And as far as I can see/remember, it doesn't need a yearly renewal...
Or I'm missing something... again...
:D
Oil spray bar for the cam I believe.
It was always an achilles heel of the Pinto - cam lobe wear.
Ta
Geoff
Ah yes... my mind was running around the Cossie head. Hadn't thought about the cam spray bar.
Still, I didn't think it was a service item...
Hi,
I'm not a hundred percent sure it's a service item.
I read a tuning book somewhere about enlarging the holes in the spray bar - I think!
Ta
Geoff
Not strictly a service item, but a notorious weak point. Probably well worth changing for the pennies it would cost
