Fog and Reverse Lights
Steve20
Just about to fit the body but have not purchaed the rear lights yet.
Question:
Is there enough room to fit the fog and reverse after the body tub has been fitted?
Appreciate that I must fit a fog light, but do I need a reverse for SVA?
Link to comment
Just fitted my fog / reversing lights one of the last jobs i had left to do on the car. No problem with tub on car ,just beware of the fuel tank .
Link to comment
You can pretty much leave fitting them till the end - but do it before you put the bootbox in. Much easier that way. It can all be done from below, but without the bootbox there's much more light.
Also, I fitted the round 'crystallight' lamps and these do not like petrol. Being just below the filler, the first time I filled up I got some blowback and the petrol cracked the lens and it's started to go matt. This probably only affects these lenses. When I upgrade to LEDs the current stop light lens will replace the fog light.
Cheers,
Kev.
Link to comment
