WESTFIELD SEIW SPECIFICATION.
Chassis kit purchased in 1998, completed build and registered in July 1999.
Black bodywork with lightweight arches
Vauxhall 2.0ltr 16 valve twin cam.
QED 450C 230/240 BHP conversion
New Q450V cams fitted January 2005
45 Dellorto twin carbs
Caterham worked inlet manifold
Solid lifters
+1mm inlet valve
+1mm Ex valve
U/light flywheel and ring gear
U/light flywheel/teeth
Worked head
Vernier pulleys
87.5mm High intruder pistons
Steel Rods
External crank sensor (omits the danger of the internal ring shattering)
AP 7 ¼ three plate clutch
QED Dry sump kit
DTA engine management
Redtop battery
Shift light
Lightweight SBD 45Amp alternator.
SBD manifold and carbon back box exhaust system.
VW lightweight radiator
5 speed Quaife semi helical gear box built by SPC.
2.39 1st, 1.54 2nd, 1.21 3rd, 1 4th, 0.87 5th
4.4 CWP limited slip Independent “Sierra” type differential
Rose jointed wide track front and rear adjustable suspension
Adjustable anti roll bars front and rear
AP 4 pot front disc callipers and vented discs
Alloy rear callipers on ford discs
Tilton quick rack
Momo detachable steering wheel
OZ 15” lightweight rims on 205 “Buffed” Toyo Proxes
FIA roll bar
SPA tacho and speedo with recall
Carbon dash
Carbon front splitter
Carbon fibre gearbox panelling
Carbon fibre bulkhead panelling
Carbon fibre boot lid panelling
Westfield race seat (s)
Harnesses
Road legal, MOT until July 2005, TAX to October 2005
Total mileage covered by this car is less than 2500 miles
Proven Sprint and hill climb car. Many Class wins. Built for the job.
£12995.00 ono.
TEL: 07976 080290 or email: david@dusc.co.uk
Don't forget his Shelsley Class Record - Wild Will Hall will be upset if it's not mentioned  :D  :D  :D  :D  :D  :devil:  :devil:  :devil:  :devil:
:blues:
